Help - MX110(z) audio input "leakage"
Mai Tai
New Member
Using "leakage" for lack of a better term. I'm hoping to get some ideas here, as this one is baffling me. Here's what's going on:
The problem:
I'm getting varying degrees of audio "leakage" from one input source to another. For example, if I have an audio source hooked up and playing through AUX, when I turn the input selector to, say, PHONO, I can still hear the AUX source faintly coming through my speakers.
I am seeing that anything line level hooked up to any of the inputs can be heard clearly when it's correlating source is selected on the input dial, yet it can also be head faintly (at differing degrees, and through either left only, or both speakers), when I turn the selector dial to any other source & turn the volume up.
FM signal does not appear to be bleeding into other sources - i.e., FM broadcasts can only be heard when I select either FM or MPX. However if I have an aux source hooked up and playing at line level, I can hear both that source as well as FM broadcast when I have it set to either FM or MPX.
I'm hearing some static through open PHONO sources too, which doesn't seem to be associated with FM, because when I found a clear broadcast signal, that broadcast doesn't bleed into the open PHONO channel - it just sounds like white noise static, instead.
What's been done so far:
The power supply on this unit was recently updated - all caps replaced, selenium rectifier replaced with silicon diode, all connections tested, and unit performed without any problems after update. All tubes were checked out & two PHONO tubes replaced - again, the unit performed well afterwards, but with some weak PHONO issues & a burned out MPX light. So, tested and verified that the MPX transistor was dead and replaced it. Also replaced 2 cracked "bumblebee" coupling caps (.1uF 300v) on the phono pre-amp tubes (both channels) as well as 2 toasted 1K 3W resistors (1 had drifted to 800 ohms).
It was only after these repairs that I noticed the audio leak. First thought was that some deoxit may have been accidentally sprayed on the input selector wafers & caused shorting. So tried gentle (no touch) cleaning of wafers with 99% alcohol, and letting it dry for 2 weeks before powering on and testing again - no change.
So, this is where I am with it. Anyone have any ideas? I don't want to mess with the input selector any more than necessary, as I don't want to risk damaging the wafers. Could this "leakage" be coming from somewhere other than the input selector switch? I'm only really assuming that it *may* be the source of the problems, but I can't be sure of it. Also worth noting is that while I replaced the power supply myself, all other repairs were done by an experienced vacuum audio specialist. We're both baffled, though, so I'm putting this out there in the hopes that someone may have experienced this issue before, and/or can offer some advice as to what to check next. Thanks!
Cross leakage isn't unusual for many preamps. The solution is to turn down or off the unused source. If a built in tuner is the undesired source, detune the station with the muting feature enabled.
Agreed with @Pio1980- crosstalk is pretty much a fact of life (especially through the phono stage) on all but the finest equipment where the manufacturer had taken special pains to prevent it- therefore it's best to simply shut down sources that are not being listened to. On the MX110, the tuner is deactivated at all non-tuner settings.
One thing you can try is connect the source to the TAPE MONITOR input rather than the AUX and see if that helps. Note this is not to be confused with TAPE HD input.
Thanks for the replies. It's at least reassuring to know that this isn't uncommon. What's odd about it to me is that I grew up with this unit since the early 70s and really just noted crosstalk/cross leakage the other week. Maybe replacing the coupling caps & resistors made it more noticeable? The white noise is still confounding, though, since there really no line-level audio source of it. I did try connecting source to tape monitor input & found no change. I heard separately that a dirty tape monitor SWITCH can cause funny things to happen, so I'll try isolating that next...
My MX110 has faint leakage from the Aux source when other inputs are selected. Was it determined if this is normal for the MX110?
A tiny bit of crossbleed is normal for many preamps and receivers. If annoying, stop bleeding signal source.
