redpackman
I am working on an a Akai X-200D tape deck. I've got transport problems. Both take up and rewind reels work great. However the capstan motor is not working right. I do have a copy of the service manual online.
Symptoms:
1. The motor has a moderate hum.
2. It will not run in 7 1/2 ips mode in either direction. It just sits there. It will run in the two slower modes, but more slowly than it ought to by quite a margin.
3. If playing in 3 3/4 ips mode (but slowly) if I hit the reverse button the capstan motor stalls out. Hit the reverse again and it will go back to playing in forward, but still too slowly...quietly humming.
4. I did try a new motor cap (2 uf 450 v AC). It made NO difference. I assume the sky blue wire is the 2 uf wire and the green wire is the common.
5.Disassembled and cleaned both the speed selection switches on the front center at least.
Is the capstan motor shot, or is there some switch/relay inside I'm missing?
Akai expert's advice would be appreciated.
Symptoms:
