Help needed with FISHER 505-T glass scale
Discussion in 'Fisher' started by jd2005, Jun 10, 2017.
  1. jd2005
    jd2005 New Member
    23
    Hi,
    I am new to this forum, but not new to vintage restoration :). Hello to all.
    But i have done one of the ultimate mistakes, ... i tried to clean the FISHER 505-T glass scale and... the cleaning material had some solvents inside it and all of the letters and digits got smeared and were just wiped out...this is how it looks like right now....
    This is how it should look like....
    I am now trying to restore the scale by printing the sclae graphics on a tarsparnet sticker and sticking it on the glass. How did i do it ? i had photos of the scale and other scales and i have redrawn the scale on top of a sample of the photos and scan of the scale. BTW - i could not find similar fonts as used on the original scale...
    But in the meantime, I am also alooking for replacement. So I am looking for the glass scale of FISHER 505-T or FISHER 450-T, which are practically the same.
    Can anyone help ? - Thanks !
  2. N8Nagel
    6,597
    Sterling, VA
    Have you tried Radio Daze? I tried looking to see if they had your glass but their site isn't working correctly right now (I know they have Pilot 402/602/654 glass as I bought one but nothing shows up when I look for it)
  3. larryderouin
    21,608
    Glen Burnie Md.
    You might also include the 250-T or TX, the 175-T, 400-T, or any of the AM/FM receivers of the same size from that era. Let em see if the 175-T glass I have is readable.
    If you have glass dimensions, the dimension from the left edge of the glass to the ZERO on the Log scale, and the 100(10) on the log scale to the Right edge, plus the height from the bottom of the lower set of numbers to the top of the upper letters.
    I can check the 175-T glass and see if it will work. I also have a 400-T here that is a parts unit. I can take mesurements on that too.
    Let me know.
    Larry
  4. jd2005
    jd2005 New Member
    23
    hi. thanks @N8Nagel. i checked with Radio Daze. they do not have it. thank you @larryderouin. i will take measurments and post back. thank you for your efforts.
  5. jd2005
    jd2005 New Member
    23
  6. jd2005
    jd2005 New Member
    23
    hello @larryderouin
    Took me some time but here are images of the scale with ruller against it for dimensions.I would appreciate if you could look and see if you have a scale with these dimensions.
    The overall glass length is 220mm and its height is 50mm
    On this image the exterioir of the ruller touches the "0" and "10" on the left and right extremes. that menas that the printed scale length is : 154mm
    The reason that you see numbers on the scale is that that i have reconstructed the scale with a CAD program and printed it on a transparent sticker. and then sticked on the the backside of the scale. it looks awfull and does not work right...
  7. larryderouin
    21,608
    Glen Burnie Md.
    You wouldn't have a NON-METRIC ruler would you. Metric is like algebra to me. Instant migraine.
    In addition to the measurements you have now, I would also need a LEFT EDGE to the ZERO on the log scale.
  8. jd2005
    jd2005 New Member
    23
    No problem ;) . Will do the same with non metric.
    Thanks !
  9. jd2005
    jd2005 New Member
    23
  10. larryderouin
    21,608
    Glen Burnie Md.
    Yeah that'll work. let me see if I have something downstairs in the crap stack.
  11. jd2005
    jd2005 New Member
    23
    Any new findings ?
  12. larryderouin
    21,608
    Glen Burnie Md.
    Sorry. Been quite busy with Honey-Do's. I'll try to get to it this week.
  13. jd2005
    jd2005 New Member
    23
    Excellent. Thank you for your help.
  14. vendo81
    vendo81 AK Subscriber Subscriber
    1,759
    California
    I think radio daze will make one for since you have the graphics and dimensions. At least they use to offer that service.
  15. larryderouin
    21,608
    Glen Burnie Md.
    I found the 175-T glass. Unfortunately it had broken during the last flooding event when I was piling gear on the old bench and didn't realize it was under the pile. It wouldn't have worked anyway as the dial measurements on the glass are offset to the left 1/4" of your measurements. The 400-T glass is unreadable.
    Sorry it worked out this way. I would go with Vendo's suggestion.
  16. jd2005
    jd2005 New Member
    23
    Hello guys.
    Thank you all for the help and support.
    For the time being i have printed the reconstructed scale on a transparent sticker and added another one on the printing itself to avoid smearing.
    I have also added a white background insteaed on black one otherwise it is not seen with the light behind.
    It will work until i find another glass sacle from a destructed receiver. maybe on ebay....
  17. jd2005
    jd2005 New Member
    23
    Hi. Reviving this/. Continuing to look for the FISHER 505-T Scale.
  18. jd2005
    jd2005 New Member
    23
    Hi. Reviving this. Still continuing to look for the FISHER 505-T Scale = FISHER 505-T Dial glass.= FISHER 450-T Dial glass. Glass Height: 2 inch. , Width: 8 7/8 inch.
  19. larryderouin
    21,608
    Glen Burnie Md.
    The lighting on FISHER Receivers of that era would have been on the end's so that the light goes thru the edge of the glass, lighting up the glass, rather than the background. Pull off the front panel and check for lamp clips right at the ends. Paint 1/2 of the glass lengthwise with white paint (Testors model paint works well). This side goes away from the glass, reflecting light back into the glass.
    You may have to buy a 450-T parts unit on Ebay or if you're in Canada a 505-T or 450-T parts unit.
  20. AlTinkster92
    AlTinkster92 AK Subscriber Subscriber
    3,148
    NC
    Try emailing Tubeycoon on the auction site, he has a ton of NOS dial glasses listed and more to follow.....
