redpackman
I've got a Sherwood S-8800 (not the 8800a). I realize that there's a service manual for the 8800a on HiFiEngine etc. and it's been helpful, because there are many similarities between the 8800 and the 8800a.
However, the board(s) on which the balance and bias setting variable resistors are mounted are not the same. On the 8800a, as clearly displayed in the above mentioned service manual, they are mounted high and low on the board. In the 8800 they are mounted at the top of the board, but I am not certain which is the bias and which is the balance pot.
Does anyone have a service manual for the 8800 (NOT the 8800a)? If so could you copy and post or send me a copy of the appropriate portions showing whether the bias pot is closer to the outputs or on the other end of the board, AND as importantly could you send the instructions for adjusting the bias and balance pots for the 8800. I Assume that the procedure (once the pots are properly identified) is basically the same, but you know what they say about people who "assume."
A schematic for the 8800 would be helpful too, but perhaps that's asking way too much.
I've also got a 120hz mild hum in BOTH channels that stays pretty steady (you can hear it as soon as you turn it on when listening with headphones) and it only increases when you turn the volume WAY up (with no other signal). With any music, it's hard to hear, but it's there. Ideas there are appreciated as well.
