Help repairing Akai AM-M939
Discussion in 'Solid State' started by tallman5353, Sep 14, 2018.
  1. tallman5353
    tallman5353 New Member
    31
    Hi there,
    Recently picked up a nice matching akai system from a garage sale, the amp being the AM-M939
    Unfortunately upon firing it up the right channel appeared to be barely working, crackling some music at times.
    I took the cover off and did some diagnostic, no outstanding dry joints, all caps and transistors don't appear burnt out. I've cleaned all of the pots and switches for balance, volume, tone etc with deoxit.
    I did swap the output transistors from each channel to the other, the problem persists still on the R.
    I also tested the idle current, the left channel measures correct at 20mv, however the right is a flat 0v. Adjusting the VR pot does nothing.
    Anyone have advice? I had a peek at the service manual schematic, but it is a bit of a maze to me.
    Thanks in advance.
  2. avionic
    avionic " Black Knights " Eagle Keeper Subscriber
    46,462
    Fort Dodge, Iowa
    Welcome to AK.. On the bad channel. Verify that the originally installed outputs are not shorted. Then verify that the emitter resistor block R39 is still serviceable. Check that both resistors within the block are not "open"..
  3. sp58
    sp58 Member
    75
    Germany
    Speaker Relay ?
  4. avionic
    46,462
    Fort Dodge, Iowa
    Relay won't fix the bias issue.
  5. tallman5353
    31
    Thanks avionic, checked both resistors. Both measure the same at 5ohms attached to the board. Any other ideas?
  6. mbz
    mbz Super Member
    2,443
    Melbourne, Victoria
    Would be nice to know what the bias transisrtor is seeing.
    If possible measure TR901b b/c/e voltages to GND/chassis.
    This can be done at the jumpers as per pix, ie, inturn,
    measure each jumper to chassis, expect about +/-2Vdc
  7. avionic
    46,462
    Fort Dodge, Iowa
    The should have been . 33 Ω each. They may be open. Need to remove it from the circuit and remeasure.
  8. avionic
    46,462
    Fort Dodge, Iowa
    Out of circuit.
  9. tallman5353
    31
    Ok, have pulled them out, readings are shown in pictures attached. Readings are the same for both resistors
  10. avionic
    46,462
    Fort Dodge, Iowa
    OK, those look good. Your test leads are probably adding .4 or .5 Ω to the measurement.
  11. avionic
    46,462
    Fort Dodge, Iowa
    Time to start taking voltage readings.
  12. tallman5353
    31
    Ok, measurements taken. Definitely a discrepancy between the two tr901's
    These are measurements taken from 901b
    avionic likes this.
  13. tallman5353
    31
    And these from 901
  14. avionic
    46,462
    Fort Dodge, Iowa
    Nice photos...Which is the emitter? Base? collector?
    Just list the voltages. photos are not necessary.
    TR901 ---- 901b
    E----------------- ?
    C------------------?
    B------------------?
  15. avionic
    46,462
    Fort Dodge, Iowa
    Next voltage measurements TR1 and 1b. TR1 is a JFET(junction field effect transistor)
    Expected readings...Drain,Source & Gate
    D-- 0v
    S-- 10.5v
    G-- 0v
  16. avionic
    46,462
    Fort Dodge, Iowa
    These look good..
    Not so good.
  17. tallman5353
    31
    Ok, TR1 readings:
    TR1
    D-- 9.4v
    G-- 0v
    S-- 16mv
    TR1b
    D-- 9.7v
    G-- 0v
    S-- 20mv
  18. avionic
    46,462
    Fort Dodge, Iowa
    TR1&2 look OK , Next E,C & B of TR6 & 7.
  19. tallman5353
    31
    Ok, i think i have the ecb the right way around.
    TR7b
    E 47v
    C -0.6v
    B 48v
    TR6b
    E -47v
    C -0.6v
    B -48v
    TR7
    E 48v
    C 1.25v
    B 47v
    TR6
    E -48v
    C -1.25v
    B -47v
    Could these transistors (6b & 7b) be the culprit, or is it further up the circuit?
  20. avionic
    46,462
    Fort Dodge, Iowa
    I'd try replacing TR901b and zener diode D3b.
