Hi fellow analoggers;
i got an Akai GX-635d that badly needs record and playback levels set. I got the heads aligned, motors and brakes...transport works great!! but when i record on good tape, setting record level at 0 db VU.... switching to tape mode it plays at less than half the record level. This is the same in forward or reverse recording mode. This is the case no matter what tape i put into the machine....it makes crisp clean recordings....just the playback levels are way lowwwwww. :nono:
Not sure of the procedure.....maybe its the same as for the GX646 or 747, i dunno. ANY help with find a service manual or set of instructions on how to adjust the rec and playback levels will be GREATfully appreciated.. If you know where i can get a manual, or instructions please private message me....thanks...
blooeyz
blooeyz
