Help/ Where to buy Scott 340b- on/off slide power switch
Discussion in 'Tube Audio' started by angel17, Mar 11, 2018.
  1. angel17
    angel17 AK Subscriber Subscriber
    267
    My Scott 340B on/off slide power switch is no good please can someone direct me where to get a new replacement or an old one in working order.
    Thank You
  2. s-petersen
    s-petersen Scott Subscriber
    4,714
    Middletown,New York
    In bartertown there is someone selling parts off of a 340, I can't see if it is an A or B
  3. angel17
    267
    Thank You s-petersen I just started a conversation.
  4. petehall347
    28,246
    uk.. the middle bit
    is there not a new one available ? or is it a special one ?
  5. Dadbar
    Dadbar Super Member
    1,884
    Waltham & Gloucester MA
    If you have trouble finding one of these I have some spares....
  6. triode17
    triode17 Super Member
    1,371
    I believe those are standard slide switches from the 60s. Try Antique Electronic Supply, they have the Switchcraft slides, which are the best IMO.
    trainbuftony likes this.
  7. gadget73
    37,335
    Southern NJ
    If its a case of an odd color paddle, you may be able to switch it over if the mfg is still in business. I've done that before, its not that hard as long as you're careful to keep track of the bits inside.
  8. N8Nagel
    6,850
    Sterling, VA
    If you don't find a working one, remind me, when I'm not at work I can look up the part that I found that was identical save for the slider. I have done this on a 340b so I know it works.
  9. angel17
    267
  10. N8Nagel
    6,850
    Sterling, VA
    I just bought a parts unit with some switches...
  11. angel17
    267
    Can I dare to ask you if you could part with one switch? Please.
  12. N8Nagel
    6,850
    Sterling, VA
    I'll check them when I get home and make sure they're the same. They have brown sliders not tan so some surgery will be involved and you'll need some aluminum pop rivers.
  13. arts
    arts Super Member
    3,893
    Qc, Canada
    Although many manufacturers have used them over the years,I have never been a fan of this type of switch. I have seen many instances where the contacts had eroded and had been arcing during operation,which can be very bad for the equipment involved. Personally,I would install a triac and use the switch (which would then be working at much lower currents,and more especially not have to handle the turn-on surge at all) to trigger it.
    Although they are overrated for this use,I had a bunch left over from another project,so I have been using them for this application.The tab is isolated,so you can mount them anywhere: https://www.digikey.ca/product-detail/en/littelfuse-inc/Q4015L5TP/F7273-ND/967490
    The circuit is extremely simple to implement,just substitute your power transformer for the lamp:)
  14. N8Nagel
    6,850
    Sterling, VA
  15. arts
    arts Super Member
    3,893
    Qc, Canada
  16. N8Nagel
    6,850
    Sterling, VA
    Mine are all tan/beige but the early SS ones are brown (what I have) so a late 340B might be brown, I honestly don't know. My 340b is before the serial break.
  17. angel17
    267
    My 340B switch is brown, I'll need one that match the original one, my knowledge to fix the old one or install anything else is null. I'm good at soldering and put it back the way is supposed to be.
  18. N8Nagel
    6,850
    Sterling, VA
    Cool well the ones I would send you are brown so you're golden. Just need to verify function
  19. gadget73
    37,335
    Southern NJ
    Me either. I use them only when I don't have a lot of choice in the matter.
  20. petehall347
    28,246
    uk.. the middle bit
    is it not a standard size ?
