Caughtthebug
Let me start at the beginning. My father in law bought this new. He put it away years ago when the pots became full of static. He ask me about it and I said let's Deoxit all the switches and pots. After a period of dry time we power it up. Everything was fine. And then nothing. Did a little research and found out about the fuse resistors. Tested and found two opened up. So I ordered every thing to rebuild the driver board and recap and replacement transistors for the other boards except the tuner section. Re did the driver board and everything was fine. Adjusted the dc offset and bias. Then I moved on to f2546, f2541, f2431, f2547 ,f2543 ,f2544, f2542, f2550 and f2597. After done found right channel some what muted and distorted. I've been over all the transistors placement as far as e c b. Pulled all of them and metered them all tested good. Check all caps and placement. Even know I checked the value of them when ordered and as I replaced. I rechecked them again. I've been checking the silk screen on the board and board layout to the schematic. And even my notes. I've been at this for a few weeks now. I know it's something stupid but where. Any help or guidance would be much appreciated. Also I ran this out of preamp in to another amp so it's not in the amp. And I have it in the aux. As well.
