Help with cleaning an old speaker surround
Discussion in 'General Audio Discussion' started by nick parkin, Aug 12, 2018.
  1. nick parkin
    nick parkin AK Subscriber Subscriber
    433
    Greetings! I just got another pair of the Coral Holes baskets and the surround on one of them has a lot of dirt on it and was wondering if there was a way to clean the surround. I was thinking maybe a q-tip dipped in rubbing alcohol? It is a fabric surround that is coated in a thin layer of rubber.
    Any tips?
  2. teal'c
    teal'c Moomber Subscriber
    18,488
    Michigan, N of Detroit
    Nope. Alcohol on rubber is not a good idea. It removes oils that the rubber needs to stay flexible.
  3. nick parkin
    433
    any way to clean them? these things are literal dust magnets and the surround has lots of large particles and dust on them!
    Im thinking maybe my Dyson with a soft bristle attachment?
  4. Marine0811
    Marine0811 I love it loud! Subscriber
  5. nick parkin
    433
    what does that mean
  6. century tek
    century tek Super Member
    3,666
    The Evergreen State
    It means that it sounds like a good idea. :beerchug:
  7. nick parkin
    433
    only problem is that the coral cone is incredibly fragile. I pushed it in with two fingers on each side of the dust cap (made sure to not push directly on the dust cap) and it dented it. Thankfully its easy to press out the dent.
  8. Marine0811
    You could also try just a dry tooth brush. Loosen everything then vacuum or knock the dust out
  9. nick parkin
    433
    I used the soft bristles to lightly loosen the dust but these surrounds are dust magnets. Ive never seen a surround that collects as must dust as these corals.
  10. reydelaplaya
    reydelaplaya AK Subscriber Subscriber
    2,693
    Aguadilla, PR
    I use a soft paintbrush and the open hose of the vacuum cleaner without attachments. Don’t get the suction too close to the surrounds or the cone just hold it about an inch or two away and use the soft paintbrush to ‘sweep’ the dust into the suction of the hose. Again, no vacuum parts too close or touching the speaker surrounds or cone - too much of a risk.
