Balinus
Hello!
So i am in the process of using Deoxit on a Sansui 9090, following the Idiot Guide here on AK. However, I'm slightly lost as to what I really need to remove and where do I actually apply the Deoxit.
From my reading, I found that I needed to remove the faceplate. However, behind the faceplate, there's another metal plate. I'm not sure if I have to remove that plate also?
Here's an image :
So, should I remove that metal plate or do I simply put some Deoxit through the metal plate?
Thanks for any help! Never did that.
Here's an image :
