SudoSpencer
Member
I bought a Marantz 2238B and when I tried it out only one side was playing. I popped the case and found that there is a bit of corrosion and rust sadly. Also the little spot labelled Q720 is completely unattached.
I am trying to learn about electronics but don't have a clue what this does or is. Can someone help me? Is this what is causing the issue. Is it safe to run without this piece soldered in?
