hagstrom71
New Member
I have a Scott 299c and the vol pot has some issues on the left channel
The left channel will sound thin and weak until the vol pot is raised to a certain level, after this point it works as normal until it is maxed out where the volume then noticeably decreases.
I'm not certain, but I'm guessing the left channel of the dual gang 500k pot is worn and needs replacing.
I've tried de-oxit without much luck, though the half of the dual gang pot closer to the face of the amp is harder to get to, so It's possible I haven't gotten into it enough.. but my gut tells me the pot is shot.
I am open to other suggestions or advice on troubleshooting.
On this 299c the power switch is on the face of the amp and not part of the Volume pot like most 299c's.
Though it is labeled 299c, it shares many similarities with the Scott 233 which I understand was common on some late era 299c's.
What would be a good 500k dual gang pot replacement for this amp?
Thanks,
Chris
Thanks,
Chris
