I have an sx-v300 that is cutting out on primarily the left channel, sometimes it will play at a very reduced volume. The right channel is usually unaffected. I would appreciate any advice in this area. I'm afraid I will have to ask you to be somewhat explicit and detailed in your advice as I am very new to repair.
I also have found a burned up resistor, it is labeled on the circuit board as R651, and is located behind the right side of the volume control slider. I can no longer read the bands on the resistor, and do not know what capacity to replace it with. If anyone has a schematic for this unit, that would be very helpful.
Thanks
Thanks
