MyLastWord
This unit I am working on, have some issue with the L/R Balance. Leaving the dial in the middle, both L/R speakers work normal. Turn all the way to the Right, both are louder. All the way to the left, almost no sound. Regards of what inputs I use or which speaker of A/B speaker outputs. I have since, clean detox all trim pot. Replace the Balance Trim pot, swap around the 2 TA7109P ICs without any affect. While at it I also did some recap. I am attaching the circuit diagram.
Where you I check next?
