1. Rest in Peace Paul (Kegger) If you would like to help the family in this time of great sorrow and need, you may donate on their GoFundme page: https://www.gofundme.com/mckechnie-medical-and-funeral-fund?
    Dismiss Notice
Help with Vintage Oscilloscope Capacitors
Discussion in 'Solid State' started by Ricktptman, Jun 18, 2017.
  1. Ricktptman
    Ricktptman AK Subscriber Subscriber
    225
    United States
    I'm restoring a vintage O-scope and its brightness isn't quite where I think it ought to be yet. I'm not a recap and ask questions later kind of restorer. (But I'll do it if I see that that it needs it.) I've only had one or two pieces of gear malfunction because of bad caps, so owing to experience, I wait until there's a problem before I go that route. There are some questions that I'd like to get advice on before I start wading into it.
    The first indicates THIS entry in the SM:
    "40 + 40MF 315V". (x2) Electrolytic
    What does this mean?
    I know that having a slightly greater voltage rating is a good thing, but I've read that you need to stay pretty close to the capacitance ratings. In the machine, I find these: (They look like electrolytics, FWIW.)
    One set of caps: .2uF 1kV
    Other cap: .2uF 2kV
    BUT the SM says these caps are supposed to be
    .1uF 1.4kV (first set)
    .1uF 1.5kV (the individual one)
    Will they sub out for each other? (I know this much, they're not easy to find.)
    Thanks in advance for any help. My experience with CRT's is very limited. This isn't in my traditional wheelhouse.
  2. NAD80
    NAD80 Well-Known Member
    843
    Carlisle PA
    The capacitance should be the same, but the higher voltage rating is better. Possible undocumented production changes. What scope are you restoring?
  3. Ricktptman
    225
    United States
    Pioneer SD-1000. There are no burns or spots on the CRT. (Even at the yoke.) It looks so close to NOS it's scary. (True for most of the machine, except for a bit of dust fog on the FP-it cleaned right off.)
    Maybe it was never THAT bright to begin with.....This is the first 1000 I've owned. I have seen a couple of 1100's but it was many years ago. It's not HARD to see, I'm just used to my '90's vintage dual trace.
    Back in the day, I'm not sure they were that super bright anyway.....trying not to (no pun intended) "gaslight" myself about it....thanks!
  4. elnaldo
    elnaldo Addicted Member
    6,334
    Buenos Aires GMT-3
    It's a double capacitor, two 40uF x 315Volt in one can. The "x2" could mean "two" capacitors, I don't think it means "X2" safety capacitors, but double check the position in circuit. "X2" safety caps are usually connected across the AC line and they are usually small film or ceramic caps, like 0.47, 0.22 or even o.o22 uF.
  5. Ricktptman
    225
    United States
    Thank you for your reply. If somebody's been down this road before I'd sure appreciate any help/assistance. I know CRT's age and I know hours powered up affects them. For me, it's just a matter of figuring out how much improvement can realistically be expected. Thanks again!
