Heresy II, Blown Woofer. Replacement Suggestions
Discussion in 'The Klipsch Korner' started by macaltec, Dec 28, 2018.
  1. macaltec
    macaltec Metal Master Subscriber
    3,971
    Bear Creek, NC
    Had a woofer give up on me last night. Not sure which way to go for a replacement.
    1) Find a K24
    2) Buy two K28E's
    3) Bob Crites
    4) Emminence Delta 12LFA
    5) Open to suggestion based on similar experience
    Thanks
  2. 4-2-7
    30,857
    San Francisco Peninsula
    What do you mean gave up on you?
  3. macaltec
    3,971
    Bear Creek, NC
    It stopped working. It has an open voice coil.
  4. Species 8472
    Species 8472 New Member
    19
    What the **** were you doing to blow a k24?
    they're tough as hell.
    it would be good to find another k24.
    If you change to k28, which is a good idea, it will require crossover changes.
    A pair of H2 to H3 conversion kits would be my recommendation.
    HomerJSimpson likes this.
  5. macaltec
    3,971
    Bear Creek, NC
    I wasnt doing anything ludicrous. Using my Sansui G6000 at a moderate volume. Thinking back on the situation I was fiddling with Spotify settings and heard a faint kinda fuzzy scratchy sound in the right channel before I started the music. Makes me wonder if perhaps the DC offset is in need of adjustment or maybe something else is amiss with the right channel. Anyway, it is out of service now and is another problem for another time. And perhaps it was a coincidence and the woofer had reached the end of its life for whatever reason.
  6. macaltec
    3,971
    Bear Creek, NC
    I really liked these speakers, more than I thought I would. My interest is mostly in not having to spend too much time messing with them and just getting back to enjoying them so that really eliminates all but finding a K24 and the Crites replacement. I doubt I will go to the auction site for a K24 so I would have to find one here on AK or locally. I do have some Delta 12LFAs that I suppose I could try. Their F3 in a slightly smaller box is 85Hz so I wouldn't expect much. Plus there's the time and messing around issue again. So, who out there has tried the Crites replacement woofers?
  7. moray james
    moray james Super Member
    3,147
    Calgary on the Bow
    before you buy a new driver take your soldering iron and re flow the tinsel lead joints on the terminal tab as you may only have a cold joint. Re flow both joints with a little fresh solder. Cost you nothing but your time and may save you a bundle.
    Hajidub and fishondwan like this.
  8. macaltec
    3,971
    Bear Creek, NC
    Good idea Moray. I checked for a loose/broken connection. I also checked the resistance on the tinsel leads as well as at the terminals. Its worth a shot.
  9. macaltec
    3,971
    Bear Creek, NC
    It's still dead. I was hopeful for a few minutes though.
  10. eiraved
    eiraved Plane Whisperer Subscriber
    2,436
    Antelope Valley, CA
    Have you checked the DC offset yet? It would be a good idea to verify it is within specs before you plug in your Heresy.
  11. macaltec
    3,971
    Bear Creek, NC
    I have not checked it. I have been using this combo on and off for a couple years now. Its stays set up. The Heresys get rotated in and out with a few other pairs of speakers. Now it's just one more piece of vintage gear added to the pile that someday will have to be tended to.
    Cant believe no one has anything to say about the Crites woofers.
  12. eiraved
    2,436
    Antelope Valley, CA
  13. njcanuck
    njcanuck aka: MacGyver Subscriber
    2,798
    Cape Coral, Florida
    My college son also blew a Heresy II woofer (and both tweeters :rolleyes:). I found one pretty quickly on eBay for reasonable money. It’s the easiest fix.
  14. macaltec
    3,971
    Bear Creek, NC
    With regard to the potential issue with the Sansui, I have rotated in the following gear and heard the same suspect noise, Fisher KX90, Pioneer Sx939, Sansui 7070 and Carver preamp/HK Citation 19 amp. I believe the noise to be coming from Schiit Modi Multibit. It doesn't not do it with other sources. Now the sound I hear is usually associated with starting a track or between tracks. Sitting idle it is quiet. Nonetheless I will be checking the G6000 DC offset soon.
  15. moray james
    3,147
    Calgary on the Bow
    did you actually re flow the joints on the terminal tab? It's a "hail Mary" but it only takes moments. I say this because I have experienced the same situation and was ready to make a big fridge magnet and was able to salvage a good driver.
  16. macaltec
    3,971
    Bear Creek, NC
    I threw the pass but there was no one there to receive it.......Yes I resoldered it.
    moray james likes this.
  17. HomerJSimpson
    HomerJSimpson AK Subscriber Subscriber
    4,486
    Winston Salem N.C.
    Just got these last week, Heresy II with bass.....
  18. macaltec
    3,971
    Bear Creek, NC
    Of course you did......lucky bastard.
  19. HomerJSimpson
    4,486
    Winston Salem N.C.
    Came with a RC3 II center, but had to drive over an hour to pick them up!
  20. macaltec
    3,971
    Bear Creek, NC
    With no door on the Jeep? No sympathy here.
