Well, one theory on the lack of bass on a Heresy, at least an early model (before the mid '70s):
Many of those speakers, were designed to work on TUBE amps, with output transformers, and therefore a relatively HIGH output impedence (ie, low damping factor).
Many of the Klipsch (as well as many JBL and such) speakers of the day, were DESIGNED to work on such amps. In these, the SPEAKERS THEMSELVES were expected to provide the damping they needed... and if you check, MANY of the drivers of the day, were VERY "overdamped" by today's standards... huge magnets, very low Q factors, in the Theile-Small parlance.
Typically, a speaker system will be designed with a Qtc (if you sealed the box) of between .5 and 1.0 . This will result in a relatively flat bass response, with a minimum of ripple. Now, if you take a low-Q speaker, and hook it up to a very damped amp (ie, solid-state modern amp, damping factor of 100 or more is typical), you get a combo that is VERY overdamped in the bass (Q of .4 or lower, many times!)... the bass will start to roll off VERY early, sometimes as early as 80-100 Hz! OTOH, hook the same speaker to a TUBE amp of the era (which would typically, had a damping factor of between 1 and 10), and the bottom end "fattens right up"... the damping is restored to a NORMAL range (total Q of between .5 and .8 usually), and VOILA! BASS! The rolloff is "propped up" to the mid-40s and below, usually!
This same effect is noted with vented boxes too... the effect will be similar in audible effect. While there may be low bass there, it'll usually sound "thin" and "anemic" on a modern amp, while nice and "fat" and "full" on a tube amp.
This is why, it's a GOOD IDEA to use vintage amps with vintage speakers. I just got through restoring a Magnavox AMP185 (6V6 outputs), that while sounds GREAT through modern speakers... the lower damping factor, and the probability that it was actually designed with a little "tip up" in the very lowest bottom end to compensate for the speakers of the day, in open baffle, makes it just a little extra"fat" in the bass on speakers made for use with modern SS amps. OTOH, I can't WAIT to hook it up to my JBL Viscount C36 cabinets loaded with Goodmans Axiom 301 woofers (whenever I can actually GET the recone kits for the woofers! Waiting sucks@&^$#&^$!!)... THAT should be JUST the kind of combo that will SING with this amp. Very efficient speaker (98 dB sensitivity... makes great use of the 15 watts), with a self-damped woofer, that should be nearly ruler-flat on this amp, to some very low frequencies...
Regards,
Gordon.
