Can a simple high blend cricuit be added to a tuner? Sometimes the hiss on weak stations is a bit much. I was thinking that it could be added right onto the output RCAs jacks of the tuner, and then it would be fixed and permanent. Some tuners have two outputs, a fixed and variable, so this could provide one output with a hi-blend and the other wide open. You could even have both hooked up to the 'tuner' and 'aux' inputs of the preamp and just select whichever 'tuner' suits the station.
I vaguely remember an article in Audio (or even Stereophile?) about adding this circuit, but I don't remember the details. It was as simple as a small capacitor and resistor in parallel across the left and right signal wires, to combine the high frequencies to mono. Problem is, I don't remember the values used. Any ieas???
