Bert 1100
Super Member
Hi all,
I bought this nice looking power amp yesterday. (No pics yet, sorry )
It's all working OK, but before trying it out in my main system I would like to make sure the idle currents are right. No DC offset adjustment here, a servo is at work
First question : is it OK to use a DBT on MOSFET amps ?
This is from the service manual :
So we have 2 trimpots per channel. One channel shown on the schematic.
The pots are not different values in series so this is not to make a finer adjustment easier.
My guess is the procedure is to balance the idle the proper way within the circuit of each channel ?
The manual procedure calls for : (green are my comments)
1) all pots to the left (I assume counter clockwise ??)
2) power on for min. 8 minutes.
3) shift all 4 pots to the center position (OK, clear, but that's already a bit frightening, I'll monitor the mV)
4) rotate pot 1 (NOWHERE does it say which pot is 1 or 2, I assume it does not actually matter ??) in the direction where the mV go UP.
5) next point, now, mentions pot 2 at the leftmost position, when did we move pot 2 back to the left ???? or was 4) just to find out the direction of rotation needed, after which pot 2 is turned back left...
6) Now adjust pot 1 to read 30mV OK, that's clear...
7) Then adjust pot 2 to read 32mV
8) Then adjust pot 1 again to finally read 33mV.
So, are any of you familiar with this adjustment in this amp ?
Am I understanding the procedure right ?
To make things more confusing, the german text says in point 4 to adjust pot 1 as to get the needle of the (analog...) VM to move LEFT, meaning down.....
(in english and french : "where the voltmeter pointer deflects in a clockwise direction", meaning UP / MORE )
I haven't yet measured the idle current as it is now, of course I will before touching anything. I'll also mark the pot's positions before touching them.
Thank you !
Thank you !
