MickeySmile
Well-Known Member
I just finished fully restoration of HK Cit.V ( recap, swap out most of old resistors, pots and old wires). After done DC and AC balance adjustment, I measured the B+ (484 VDC), the voltage from wall is 125V.
According to Jim McShane page, the B+ is 440 - 460 VDC but in his notes: "Variations of 10-20% in the readings can usually be considered normal". Should I put in resistor for dropping B+ voltage or leave it.
Thanking you in advance for suggestion.
Binh
Binh
