JoshHendi
^ElectroNerd^
Hey everyone so I got a 5500 receiver and the manual has a weird procedure for checking/setting bias by checking external fuses, with a weird on/off guide and I haven't had luck. (Followed the manual, gone threw a meter fuse or two [and yes my meter was set right], just a real PITA process)
What I am hoping is that one of you wizards can do the calculation so I can measure the bias in DCmv on the emitter resistors. I have seen on other Sansui amp threads that people bypass the fuse readings because a wizard knew what the measurements on the emitter resistors were. And that way I can make sure the bias is balanced on both channels by not having to turn it on and off constantly for L/R readings.
Attached the manual to help. If anything else is needed (voltages or whatever) please let me know!
