oldman55
Well-Known Member
Been pretty lucky on my "as-is" buys but may have got a bitten off too much on this one.
There are enough indicators on this that I am sure someone could help me with an initial assessment.
The rectifier/power tubes look to have gotten a little hotter than normal.
This may be over my head as some of the components are stacked three high in a tight chassis. But built like a tank and in great cosmetic shape so gotta get it back up. It was going to be hard enough to do a recap but now, IDK about the OTs.
Two of the EL84 sockets are clogged as if it was used with only the other two tubes. Without a rectifier, can I do a quick check of the transformers? Started to do on another unit but stopped to wait for a SSR. Still dont have one. If I knew they were good, I would just start replacing parts as all controls seem good and cleaned up well.
Most of the resistors near the output are out of tolerance to the high side.
Photos probably tell the story better than I.
Photos:
Front
Belly
Lotta wax
Growth/crud on square cap
Clogged hot sockets
charred resistor lead
cut/flagged at selector
Photos:
Front
Belly
Lotta wax
Clogged hot sockets
