Hello
Anybody out there who services hot tubs / spas?
I have a 2002 Jacuzii J355 hot tub that will not respond to any button pushes from the keypad.
It does display the temp and it is running the circulation pump constantly.
I do not know if the CP should run constantly or not.
The heater is working and turns on and off when needed.
So how can I determine which piece is bad?
The key pad costs 373.00 the circuit board is 425.00 plus shipping
I have looked at both and nothing obvious is wrong I did find one pin on the eprom on the circuit board not
inserted correctly it was bent out not sure if it was making contact or not. Corrected this no change.
I have found I can buy a replacement pack consisting controller and key pad plus a heater for less than
the cost of the two pieces mentioned above.
So feel free to let me know what you think or what I can try to do to.
