How balanced is balanced?
Discussion in 'Tube Audio' started by Sleigo, Oct 13, 2018.
  1. Sleigo
    Sleigo New Member
    12
    I have a Mcintosh c2600 tube pre-amp. I have noticed of late that the output gauges occasionally vary between left and right; is this a feature of the source (ie the record or CD) or is this a problem with my pre-amp? Sorry, newbie question with no tech savvy
  2. kward
    kward AK Subscriber Subscriber
    3,602
    Utah
    Rig up or purchase a Y adapter and drive both preamp channels from the same source. That will tell you if it is the preamp or the source.
  3. triode17
    triode17 Super Member
    1,390
    If you are monitoring a stereo signal, then the signals will vary from each other on the meters.
  4. Yamaki
    4,351
    Hillsboro, Oregon
    The frequency production is not the same across both channels.
    You'll notice the needles "bounce" at varying levels. That represents not only the the volume level of the music in that channel, it also reflects what is being produced at that moment on that channel.
    It's called "separation" which provides the distinct sound of each instrument and voice reproduced by the music. Those levels are separate and they vary as the material was mixed to place certain instruments on specific channels during the recording process.
  5. Sleigo
    Sleigo New Member
    12
    Thanks. This is what I thought... some confusing info from someone.
    It is just variation from the original recording.
    Appreciate you.
  6. kward
    3,602
    Utah
    Just understand it could be possible there is an issue with the preamp. Driving both channels from a single source would identify that. But yes, apologies for not being clear. stereo signals are not supposed to be identical.
  7. Sleigo
    Sleigo New Member
    12
    Thanks kward, if anything looks crazy off I will try your method with a Y
  8. 4-2-7
    30,497
    San Francisco Peninsula
    You don't have to go through any cable changes from the source. Both channels should be different as Michael said above in stereo. However if you want to see if both channels operate the same, you have a mono switch on the preamp. If you set that to mono it should show the meters moving the same output at the same time.
  9. frahengeo
    frahengeo AK Subscriber Subscriber
    831
    Massachusetts
    As a sanity check, you can always swap the left and right to see if the lower VU follows. Of course, this assumes that there are particular passages or sections of a song/album where the differences were observed.
  10. crispycircuit
    crispycircuit AK Subscriber Subscriber
    1,465
    near Buffalo NY
    The Vu meter circuit may have an adjustment & need to be calibrated it self. A repair service manual would have the info.
