The example schematic below shows a "normally" wired EFB regulator for a PP output stages for a stereo chassis configuration. The 380V from the point labeled A comes from the center taps of the output transformers. The 326V from the point labeled D feeds the screens of the output tubes, and the -42V from the point labeled E, is the bias voltage for the output stage.
But when the output stage is connected in Ultra Linear mode, there is no need to supply the screen voltage from the EFB regulator since it's obtained from the OPT's UL taps. How would the wiring of the EFB regulator need to change to support a UL connected output stage?
I can see how possibly either of these two answers below would be correct:
- Keep everything the same, just don't connect the screens to point D. (feed the screens from the UL taps on the output transformers instead).
- Since the mosfet is now not used, remove it from the circuit, and feed the 1M voltage sense resistor that is connected the base of the inverter transistor directly from point A. Of course that will slightly change the other resistor values in the EFB circuit since there would be more current now flowing through that 1M resistor than before, but that's okay (if this is the right approach) since I can redesign the rest of the EFB circuit to support the new voltages/currents.
