How do I start streaming music?
Discussion in 'Digital Sources' started by grillebilly, Sep 9, 2018.
  1. grillebilly
    grillebilly Empty Head Subscriber
    16,285
    Fairfax VA
    I am considering joining the 21st century and streaming music at home. Where and how do I start? I do not have a smart phone. I have a computer obviously.
    My preamp (McIntosh C47) has a lot of inputs, including a USB port. Is there a device that can plug into one of the ports and stream wireless from my computer? Is that a preferred method?
    Any and all advice is welcomed and thanks in advance.
    sfox52, E.Man and 2N697 like this.
  2. palsapal
    palsapal Active Member
    149
    nr Southport, UK.
    Have a look at Chromecast Audio which is a small device that plugs into your hifi using RCA phono inputs. Once set up this communicates with a router via wifi & any music-playing device connected to the same network can play its files on the hifi. I have one & play music files on my desktop (wired to the wifi router) to my hifi on the other side of the room using wifi.
    sfox52, E.Man and grillebilly like this.
  3. cpt_paranoia
    cpt_paranoia Super Member
    1,090
    Streaming from where? A commercial service? Your PC? A NAS?
    The simplest method is a 3.5mm to RCA lead from headphone output of your PC to a line input on your amp, with a streaming service program, or media player/manager program on the PC.
    Beyond that, you have many choices of how to get audio files from the PC to a DAC, and thence to your amp.
    Have a read of these threads:
    http://audiokarma.org/forums/index....ur-digital-files-to-your-hi-fi-system.826709/
    http://audiokarma.org/forums/index.php?threads/questions-on-making-server-for-flac-playback.742307/
  4. Rockyhill
    Rockyhill No marigolds in the promised land Subscriber
    3,221
    Maine
    OutlawSun, E.Man and grillebilly like this.
  5. grillebilly
    16,285
    Fairfax VA
    I am thinking of subscribing to a service through my computer. I don't want to listen on the cheap computer speakers, though, it needs to be somehow connected to my main system. Sending a cable from the computer to the pre is not something i want to do, as they are far apart but still in the same room.
    Thanks for the links I will take a look now.
  6. chicks
    chicks Lunatic Member
    18,350
    The Big Valley, CA
    Balrog2112 and +48V like this.
  7. PAGS
    PAGS AK Subscriber Subscriber
    2,168
    North of Philly
    For the absolute cheapest way to get started, get one of these:
    A 3.5mm to RCA cable.You likely have several of them lying around. Or you can buy from Monoprice cheap (or Amazon, etc.) -- as long as 50 feet. Plug the single end into your computer, speakers out, and the double into a pair of available RCA ins on your preamp.
    Then go here and set up a free Spotify account: https://www.spotify.com/us/. The free service is lower quality and has commercials, but it's free. You can always upgrade later if you like it.
    Stream...
  8. grillebilly
    16,285
    Fairfax VA
    It looks like I need a phone or other chromecast device to use it.
  9. grillebilly
    16,285
    Fairfax VA
    Thanks, that looks easy enough but the description says it's a speaker. Does it get bypassed when run into another system?
  10. mkane
    mkane AK Subscriber Subscriber
    6,547
    103 miles N. of S.F.
    pc works also
    grillebilly likes this.
  11. PAGS
    2,168
    North of Philly
    See above. Note that Chromecast Audio generally doesn't work well with just a computer (but there are some workarounds you might consider after getting your feet wet).
    Bill Ferris and grillebilly like this.
  12. grillebilly
    16,285
    Fairfax VA
    Ok it looks like I can download Chrome to my PC. And then I should be good to go.
    E.Man likes this.
  13. Rockyhill
    3,221
    Maine
    No phone needed, although having a smart phone makes using a CCA even more convenient. Just review the instructions I gave in the link.
  14. chicks
    18,350
    The Big Valley, CA
    Yes.
  15. Rockyhill
    3,221
    Maine
    Walmart sells them. You could be casting in a few hours.
    BDylanThomas likes this.
  16. grillebilly
    16,285
    Fairfax VA
  17. 4-2-7
    29,804
    San Francisco Peninsula
    PC> Audioengine D2 24bit WiFi DAC>McIntosh
    You don't need a service, plenty of music out there and your computer files are not dependent on the quality of your internet.
    OK I forgot you have a nice DAC
    PC, USB out> Audioengine D2 24bit WiFi DAC, Optical out>McIntosh Preamp Optical in
    Bill Ferris likes this.
  18. PAGS
    2,168
    North of Philly
    You can also get a used Galaxy tablet for as little as $20 and "dedicate it" to streaming via CCA. I use an el cheapo Verizon Elypsis 7. Works great.
    ChicagoTom and grillebilly like this.
  19. grillebilly
    16,285
    Fairfax VA
    Looks like there are lots of choices. Thanks.
  20. PAGS
    2,168
    North of Philly
