    Dismiss Notice
How loud do you normally listen to music?
Discussion in 'The Cutting Edge' started by Blue Shadow, Jul 19, 2015.
  1. Blue Shadow
    Blue Shadow I gotta get me a new title
    21,507
    SE PA
    loud for me is all the amp has but it is driving low efficiency speakers so maybe 100dB and a little more.
    Normal is well below that. Unless I'm engaged in serious listening, I'm probably somewhere in the 70s.
    I use earplugs anytime I'm using loud tools, lawnmowers, blowers and such or as needed professionally.
    Let me add this...most will listen at different volumes, depending so I've put in normal and loud levels. Let's see both if you know them.
  2. Pio1980
    Pio1980 AK Member Subscriber
    27,096
    Eastern Bamastan
    90-95 dB peak, measured at listening position. 80-85-90 dB otherwise.
    Sent from my SM-N900V using Tapatalk
  3. mhardy6647
    52,926
    Usually low to mid 80s average at my listening position per an R/S analog SPL meter.
  4. BillyBatts
    BillyBatts ALOHA! Subscriber
    Really depends on mood, time of day, room, and situation.
    Mid 70's a lot. Maybe 60's for background music.
    80's when I'm working out or focusing on the music totally.
    90-95 peak if I'm just wanting to crank some Rock for whatever reason.
  5. mkane
    mkane AK Subscriber Subscriber
    6,399
    103 miles N. of S.F.
    ^^^^^^^^^^^^^^^^^^^this for me also.
  6. dcmfan
    dcmfan AK Subscriber Subscriber
    3,858
    Welcome 2 Missouri
    Same here.
  7. KingBubba
    10,012
    Brooksville, Fl.
    WHAT?????? :tears: Can you spell tinnitus?
  8. jcamero
    jcamero Who are you people anyway? Subscriber
    4,145
    The Bright Side of Life
    Right now, due to poor room acoustics, low levels.
  9. mpholland
    mpholland R.I.P. Michael Sheppard Subscriber
    4,044
    Crooked River Ranch, OR
    Normally low to mid 70's, but on a rare occasion into the mid 90's. My wife will usually turn it up higher than I do.
  10. damacman
    8,818
    Gilbert, AZ
    Not nearly as loud as I used to ...
  11. faber12
    faber12 Super Member
    4,059
    Northwest Ohio
    Normally 80 db peak, loud is 90-95 peak.
  12. TEA FOR ONE
    TEA FOR ONE AK Subscriber Subscriber
    1,668
    Rochester.NY
    75-80ish when no one is home. Otherwise,65ish.
  13. mhardy6647
    52,926
    I am kind of surprised by the low listening levels many of you/us manifest. 60-65 dB is, I think, in the realm "background music" realm. That's certainly good for preserving one's good hearing, but seems a tad soft to me for "serious" listening.
    PLEASE note that this isn't a critique, merely an observation!
    source: https://www.osha.gov/dts/osta/otm/noise/health_effects/soundpropagation.html
  14. Blue Shadow
    21,507
    SE PA
    I know two AKers that listen at very low levels. One at a level that leaves my ears reaching out for the music. Somewhere in the 60-70dB range. The other is maybe up to the low 70s.
    Desired volume changes with experience whether that life brought issues when listening louder or others that don't want to hear the music play among many other reasons for this change. I believe this is the case with these two members. Enjoying music at lower volumes just works for them.
  15. mhardy6647
    52,926
    It is certainly healthier!
  16. BadassBob
    BadassBob Digitally rendered
    5,628
    home of the GM Tech Center
    If I'm not actively listening, I go 60 to 70dB, and when listening critically, I'm usually 80 to 85dB....according to my SPL meter.
  17. TJLitt
    TJLitt Super Member
    1,456
    Wilmington, DE/Parksley, VA
    Am I one of the above?? At any rate, I do a LOT of listening at what I'd estimate to be around 70dB. I'd prefer to bump it up a bit(Blue's description of reaching out for the rest of the music is apt), but am trying to balance the positive effects of music with listening for grandchildren or other moving hazards in the rest of the house. For listening gatherings, or my own serious listening, I try to keep it under 100dB, but not too far below. I strive for what I'd describe as live show levels, maybe a bit back from the stage/PA.
  18. Blue Shadow
    21,507
    SE PA
    No Tom, not you. I know you and most of the others have generously placed the volume control in such a position that all can hear the music when you guys drop by. We need to do that again.
  19. Chubba
    Chubba Active Member
    487
    StCatharines Ont Canada
    I tend to listen at the level the music requires.From Simon and Garfunkel to AC-DC Hells Bells.I am trying to time it that my hearing,heart,lungs and liver have had enough at about the same time.:D
  20. stish
    stish AK Subscriber Subscriber
    679
    Huntsville AL
    Same here, (without the otherwise).:D
