I read this and I find its interesting that most people listen at about 85-90, just as I do. This is basically the 1w. level. Maybe its true what they say, "An amp, is only as good as it's first Watt."http://www.audiokarma.org/forums/index.php?threads/how-loud-do-you-normally-listen-to-music.670007/ for you to check out while you wait for more answers.
Normal level sitting in my sweet spot....11' equilateral triangle is 72db.
Rocking hard is 119-124db.
Remember that every time you go up 3dB you double the sound level. Actually this isn't quite correct, it's actually about 6dB, but that's only because human perceived level is different to measured level. Weird isn't it.
So basically 90dB is twice as loud as 87dB. It's surprising how low a level that a hifi amp normally actually runs at. It normally averages at just a few watts as an average value, but musical transients can produce surprisingly high levels.
It all depends upon how you measure it.
Buuuut, and this is me asking a question, under 200hz peaks would be much more demanding than over 200hz peaks. Obvious there are some sounds floating around there, but the required wattage to push a driver at 1khz/89dB has got to be a magnitude lower than to push a driver at 100hz/89dB.The average listener listens around 85 db, slow and A weighted. Professionals and audiophiles up to 5 db more. That means you need to figure 6 to 10 db more for peaks. As Average speakers sensitivity now days is 90 db at 1 meter if you listen at 12 ft from one speaker that would mean your speaker would have to put out 102 db if the room were very dead and around 96 db in a bright room for an average sound level. Peaks could add another 10 db or any where from 112 to 106 db. That would be any where from 40 to 150 watts, per channel. Thats not to bad. If you had Klipsch Cornwalls that would be about 3 to 6 watts, and La Scalas would mean 1.5 to 3 or 4 watts. Of course of you had the new Magnapans 30.7 you would need around 600 watts. $ 30,000 for speakers and another 15 to 20,000 for amps. Ouch.
What ist SFO?PS: if you should get stuck overnight at SFO, the recorded public-service security announcements are about 100dB, and they repeat every 90 seconds. All night long. You won't be sleeping. Guess how I know.
