You count, most are circulated from storage into use on a three month cycle.
Apart from two pairs of Meridian M2's; type A and type R crossovers.
I have three pairs of the following :
JR149 Red label, Gold label and Gold label with fuse, plus a pair of type 24 crossovers .
I have two pairs of the following :
Lentek Monitors, Atkinson SOTA's, Cambridge Audio R50's, LS3/5a's (Audiomaster and Chartwell).
KEF Reference 105-2, 104aB, 103-2, 103, 101.
KEF Cadenza, Cantata, Calinda, Corelli, Chorale, Caprice II, Carlton II, Carlton III.
And one pair each of these :
KEF Reference 105-4.
KEF Concerto with type 33 crossovers, Cantor, Coda, CS7, CS9.
Klang+Ton B110B/T27 transmission line with KEF Ref. 101 crossovers
KEF CS box with Falcon 23aB crossover, KEF B110A/T27A.
Tangent TM1, TM2, TM3.
Mordaunt Short MS 737, MS 235.
Monitor Audio MA1 mkII, MA4 mkII, MA5 mkII.
Cambridge R40 with type 53 crossovers.
LNB Paralab 40, LNB Paralab 20 a three way and a later two way.
Stag Audio Ambassador 30.
Celef "Micros" KEF B110A/ Peerless DT10HFC.
Commecially built by an ex-Radford employee in Filton Bristol, two way transmission lines a'la SMC on custom stands with SP1014 above SP1032.
Bailey transmission lines.
Three way KEF B110A, Peerless KO10DT, Coles 4001G Daline.
A KEF IMP design using an SP1022 with Celestion HF1300 and Coles 4001G retrofitted into old Richard Allan boxes - any cabinet makers want a little job ?
A pair of "horny subs" SP1054 in Lowther modified B&W DM2 cabinets, plus a tiny bit of damping to kill the first reflection. Used in active configurations below ~160Hz.
I also have a pair of KEF 104 kit baffles with ABR's that have had a KEF crossover upgrade to 104aB specification .
Outside the scope of my collection (1976~1986) :
LNB Paralab 20s with "rabbits ears" B200s and A6535 T27s.
KEF K2 Celeste using a B139A and T15.
Pictures and additional information about some of my collection may be found here :
http://www.hifiloudspeakers.info/
http://www.thunders.ca/tangent/index.php
http://groups.google.com/group/vintage-cambridge-audio
http://www.soundfountain.com/amb/ribbon.html
I would still like to add a pair of late KEF Concerto's with the " vinyl veneered" front baffles, but thanks to ePay probably not .
This post or any other information supplied to this website or any other by myself is not available as sales and marketing material for ePrey pimps and the like.
