As the title, how do I find gain of triodes and penthodes if you put a degenerate cathode resistor.......with NO bypass cap. I don't recall I ever seen any talk about this, if anyone can point me to some reading material, that would be very helpful.
In transistors, it's easy, we just use gm=1/r'e to calculate the gain of a common emitter stage. Can you use 1/gm on tubes to find the equivalent internal cathode resistor. Then if you add a cathode resistor, then the total cathode resistor = 1/gm + Rc. then you equate the new gm'= 1/(1/gm + Rc) and use the new gm' for calculate the u and gain.
