I am filling in the mental "big picture" here and I want understand the link to a 2 channel system without using WiFi.
I guess that there are media receivers that have a RJ-45 jack and that you can connect it to your network and (I think) send media files to it via an app on your phone or tablet. Even if that is the case I would rather use anything from a vintage receiver, powered speakers or a T-amp as the final link in the chain.
I see that there is an ethernet adapter for the Chromecast Audio. It seems that then you need more to have less (i.e., buy an adapter to NOT have WiFi). That is an option I guess.
Looking at Allo, PiCore, etc documentation I still can't tell if these devices can be "network DACs". I know they have an RJ-45 jack and WiFi capability. It just isn't explicitly stated that either connection to the network can be used to send (remote controlled) files to it on their way to some 2 channel end point. Can they?
What I don't see is off-the-shelf, small form factor, inexpensive, devices that are basically ethernet DACs.
I understand that I will still need WiFi to control this sort of set-up with a phone or tablet in any case.
I understand that some locate a laptop/desktop near their audio system and use the 3.5mm jack or a USB DAC. I do some of that already but would like to see a single small device replace the laptop.
