How to power on amps with no on/off switch?
Discussion in 'General Audio Discussion' started by z-adamson, Sep 10, 2018.
  1. z-adamson
    z-adamson Super Member
    1,767
    I know I can plug in and unplug to turn on and off, but I was hoping that there is a better way.
    Is there some kind of power strip with a heavy duty switch that would allow for powering on and off amplifiers? A switch heavy duty enough to power of 2 or 3 amplifiers at once without wearing out in short order?
    Amplifier in question: Hafler DH200 with switch bypassed.
    If I could hook 3 DH200 amps to a single strip and power on and off all 3 at once and do so reliably, cool. What kind of strip would you recommend?
  2. petehall347
    28,254
    uk.. the middle bit
    1800w at 120v . but there will be spike as they charge up ... i would go for highest rating of the outlet .. not a good idea going larger .
  3. z-adamson
    1,767
    What if I was to make my own box, wire it with 10 or 12 gauge, use two duplex receptacles and a single toggle switch (like a light switch). Receptacles and switch rated to 20 amps?
    Would this work? I am more worried about the switch than I am the receptacles. Turning off and on with this load could lead to arcing and premature wear I think.
    It's mostly the surge at turn on that can result in high current draw. In use, they will not be playing full-tilt...
    opusarlo and I LIKE MUSIC like this.
  4. petehall347
    28,254
    uk.. the middle bit
    light switches so far as i know wont be expecting the same current as something plugged into the wall .. you have to check the current rating of what you want to use . which cannot be more than is available . well it can for a brief moment ..
  5. avionic
    45,546
    Fort Dodge, Iowa
  6. petehall347
    28,254
    uk.. the middle bit
    ideal for a 24v DC fairground merry go round .. that switch reminded me about the job i was called out to do ...
  7. WaynerN
    WaynerN AK Subscriber Subscriber
    5,815
    Minnesota
    Light switches have the same amperage rating as the branch circuit, 15 amps. These switches are also used to make outlets switched to operate table lamps, etc.
    Bill Ferris and pskaudio like this.
  8. robert_kc
    robert_kc AK Subscriber Subscriber
    895
    Midwest USA
    Wemo Mini Smart Plug (approx $30), rated at 1800 watts.
    opusarlo likes this.
  9. hugo454
    hugo454 Gold Member Subscriber
    1,591
    south florida
    Line conditioner
    And some of them have built in delays so that they don't all start at the same moment
  10. petehall347
    28,254
    uk.. the middle bit
    different there than here then ..
  11. bowtie427ss
    bowtie427ss arigato gozaimashita
    17,307
    Land of Milk & Honey Boo Boo
    If the amplifiers don't have in-rush current limiting you need to power them sequentially.
    Google "power sequencer"
    The "Rockn Stompn" is pretty cool with adjustable delays.
    http://www.rocknstompn.com
    opusarlo and Bill Ferris like this.
  12. Hyfi
    Hyfi Addicted Member
    5,859
    Bucks County, PA
  13. hjames
    hjames beware - winter is HERE! Staff Member Moderator Subscriber
    12,513
    VA near DC
    I use Adcom ACE-515 switches and power conditioner units. Its an old Vintage piece -
    it has a sense cable you plug into a switched power outlet on your preamp, tuner or whatever you use as a friend end -and provides delayed power up and power down sequences for your power amps.
    I have 2 in my system, one for the main power amp, and one for the secondary 5ch amps for surround channels.
    Bill Ferris likes this.
  14. savatage1973
    6,675
    NW Pennsylvania snow belt
    I use Furman or Monster Power units on all of my systems--surge protection, line conditioning, and sequencing functions--so one switch powers everything up and down in proper order.
  15. gadget73
    37,362
    Southern NJ
    You can buy 20 amp rated switches too. Often they're sold as furnace cut-off switches. I would not use a typical cheesy light switch for something like this. Of course I don't favor the typical cheesy outlets either. I like 20 amp ones with the wire clamps, not the cheap ones that the wire has to wrap around the screws on.
    or replace the switches in the amps and just turn them on in the usual manner.
  16. c.coyle
    c.coyle Fighting the Dunning-Kruger effect. Subscriber
    3,330
    40.339044,-76.423500
    A 40 amp triac controlled by a light duty switch? The switch just handles a small gate current, the triac takes the big hit. There's a thread here about switching a single amp with a triac. Shouldn't be hard (or expensive) to do.
    I LIKE MUSIC and Bill Ferris like this.
  17. z-adamson
    1,767
    You can also buy 30 amp switches (that look like light switched).
    I am thinking about building something with 20 amp receptacles and 30 amp heavy duty switches.
    Still not sure if they are rated for this kind of use.
  18. z-adamson
    1,767
    Is it 1800watts at idle or at max output?
  19. petehall347
    28,254
    uk.. the middle bit
    says 600 max on rear panel . so can only think it is the max it will ever draw .
    although start up current may well be briefly much higher .
    I LIKE MUSIC likes this.
  20. z-adamson
    1,767
