How to pull these tubes?
Discussion in 'Tube Audio' started by FauxHall, Dec 7, 2018.
  1. FauxHall
    FauxHall Super Member
    1,677
    Abu Dhabi, UAE
    My system has only two tubes - the pair of 12AX7s in the Pro-Ject Tube Box DS, my stand-alone phono stage.
    I'd love to do some tube rolling on these but I don't know what I've got nor how to pull them out to see. They might be branded as Pro-Ject anyway.
    Question #1 - how do I get these out? I can't seem to get a decent purchase with my fingers.
    Question #2 - what would be good replacements?
    To Pro-Ject's credit, the installed tubes have tube cooler/dampers.
  2. luvvinvinyl
    luvvinvinyl Lily! Staff Member Admin Subscriber
    25,909
    South of Detroit
    Rubber gloves?
    Failing that, it appears the the back plate can be removed after removing two screws. That may get you access to the tubes. Or, check to see if the feet have screws, which may be holding the bottom in place. Suss it out, the best you can, go slowly, and take pics before each step.
  3. Dandy
    Dandy Super Member
    4,634
    North West, UK
    Bill Ferris likes this.
  4. maxhifi
    maxhifi AK Subscriber Subscriber
    3,403
    Edmonton Alberta Canada
    I'd take the unit apart to expose the board, and then just unplug them. The tube coolers appear to make getting a decent grip from above nearly impossible.
    For 12AX7 in a phono pre the main requirement is low noise. I would therefore suggest old stock Mullard, Telefunken, or Philips tubes.
    For newly made tubes I would say the generic Chinese 12AX7 can be surprisingly good. I don't much like the Russian sovtek/EH 12AX7, and the JJs didn't do it for me either. Some of the newer boutique tubes may be good, I don't know though never tried them.
  5. FauxHall
    1,677
    Abu Dhabi, UAE
    I think these tubes are just a buffer stage after an op amp. I don't think low noise tubes, like 7025s, are critical.
    Does anyone have a schematic? Not on HiFi Engine.
  6. triode17
    triode17 Super Member
    1,389
    You should send this question to Pro-Ject.
  7. primosounds
    2,994
    Terra, 21st century CE
    The tube coolers should slip off the top. After that it should be possible to remove the tubes. I saw somewhere a tube removal tool that is like a baby bottle tongs with rubber grips over the metal part to help remove tubes.
  8. Lavane
    7,848
    northern cal.
    Some are rubber, kind of like a tiny toilet plunger.
    primosounds likes this.
  9. primosounds
    2,994
    Also the "Chinese finger puzzle" kind.
    Lavane likes this.
  10. FauxHall
    1,677
    Abu Dhabi, UAE
    Thanks for all the input. I'll email Pro-Ject for a service manual.
  11. Dandy
    Dandy Super Member
    4,634
    North West, UK
    It's rather poor of Project not to explain this in the user manual.
  12. Lavane
    7,848
    northern cal.
  13. gadget73
    37,721
    Southern NJ
    any chance it has a hole through the bottom where you can insert a pen and push it up?
  14. FauxHall
    1,677
    Abu Dhabi, UAE
    Sorry, but I have no faith in my technician skills so no go on opening up the box. I can take off the tube guard but after that, I pay a pro do dig deeper. I like the fishing line as loop to extract the tubes.
    I'll see if there is a local supplier and if not, I'll order a couple of pairs to roll.
  15. Dandy
    Dandy Super Member
    4,634
    North West, UK
  16. Lavane
    7,848
    northern cal.
  17. FauxHall
    1,677
    Abu Dhabi, UAE
    The box looks like a forging or extrusion. One probably slides out the guts from the back to the front after removing the screws in the bottom but even that looks like it requires the tubes to be pulled first.
    Awaiting the service manual
  18. Dandy
    Dandy Super Member
    4,634
    North West, UK
    Have you tried pulling out the tube guard out leaving the tubes behind? Then pulling out the tubes, maybe with rubber gloves for extra grip?
    Why do I suspect that the service manual won't tell you how to pull the tubes?...
  19. Lavane
    7,848
    northern cal.
    Two pair of needle nose pliers? Grab a fin on each side of the guard and gently wiggle it up?
  20. KlipschFan61
    KlipschFan61 Smooth Jazzer
    982
    Manchester, NH
    That's a pretty funky setup for sure.
