Pull off the center spindle. It's just a friction fit.
Find a small flat head screw driver and locate the slot in the center post.
Locate the clip with it and pry up against the other side of the center post taking care NOT to damage the decorative brushed aluminum escutcheon.
Sometimes the open slot in the C clip aligns with the open slot in the center post. Just use the edge of the screw driver to slide it around so you can get hold of it.
I hate it when the clip rotates so that the slot lines up with the gap. It has fooled me for a few seconds into thinking there is no ring and the platter is stuck, but as you say is easy to remedy.
The little aluminum center ring in the mat is easy to bend so be careful with the screwdriver. A little hooked dental pick is good at getting under the clip with levering and is less likely to press against that little plate.
It's not necessary. Unless you, for whatever reason, like to turn your turntable upside down and have the platter stay on. I wouldn't recommend doing that anyway and don't know why you would. I rarely put the clip back on any of the Duals that use it.
If you want to control its possible dash for freedom, get a clear plastic bag big enough to put the whole TT in, and work inside that. Drycleaning bag or clear leaf bag will do.
Chip
Chip
