dr*audio
Fish fingers and custard!
This has been around for years, but some of you may not have seen it. Thought it would give you a chuckle:
HOW TO REPAIR ELECTRONIC EQUIPMENT
1. Approach the ailing instrument in a confident manner. This will give the instrument the mistaken idea that you know something. It will also impress anyone who happens to be looking, and if the instrument should suddenly start working you will be credited with its repair. Should this fail, proceed to step 2.
2. Wave the service manual at the instrument. This will make the instrument assume that you are at least familiar with the source of knowledge. Should this fail, proceed to step 3.
3. In a forceful manner, recite Ohm's Law to the instrument. (Caution:
BEFORE TAKING THIS STEP, REFER TO A HANDBOOK TO BE SURE OF YOUR KNOWLEDGE OF OHM'S LAW.) This will prove to the instrument that you do know something. This is a drastic step and should only be taken if the first two steps fail. If this step fails, proceed to step 4.
4. Jar the instrument slightly. This may take anything from a three to six foot drop, preferably on a concrete floor. However, you must be careful with this step because, while jarring in the approved method of repair, you must not mar the floor. Again, this is a very drastic step. If it should fail, proceed to step 5.
5. Brandish a large screwdriver in a menacing manner. This will frighten the instrument and demonstrates the deadly "SHORT CIRCUIT" technique. If this step fails, proceed to step 6.
6. Add a tube...even if the instrument is solid state. This will prove to the instrument that you are familiar with the design of the instrument. Also, this will increase your advantage and confuse the instrument. If this step fails, proceed to the most drastic and dangerous step of all, step 7. It is very seldom used and is the last resort if all else fails.
7. Think...!? Last resort if all else fails.
