How to ship a 40 pound speaker
Discussion in 'Packing & Shipping' started by Wardsweb, Nov 29, 2005.
  1. Wardsweb
    Wardsweb Behind The Curtain Staff Member Admin
    7,161
    San Antonio, Texas
    Thought I would show how I packed a McCauley 6174 18" ultra sub. This thing is huge and comes in close to 40 pounds before boxing. I started with a 350 pound double wall box. I lined the bottom with 2 inches of high density foam. I bolted the driver to a piece of 1/2 inch plywood using 1/4" bolts and star nuts. It is held in place with styrafoam corner blocks. These are held in place with 1 inch foam sheets. Then I added 2 inch block to keep the entire piece from lifting off the bottom. I cut some 2 inch foam to fit around the magnet assembly and filled it with three more pieces of 2 inch foam. This thing is bullet proof now. I know it's serious overkill but new this driver was $800. I sold this one on Ebay for $410.
      File size:
      85.3 KB
      705
      File size:
      86.6 KB
      514
      File size:
      79.8 KB
      498
      File size:
      70.8 KB
      317
  2. markthefixer
    21,202
    Bensenville,Illinois
    Dat foam is sure purdy.....
    Is it more like extruded( hard) or expanded (softer, like a styrofoam cup) polystyrene, polyethylene or like carpet padding?
    Where did you get it...
    (almost) dying to know...
    mtf
  3. Wardsweb
    7,161
    San Antonio, Texas
    I'm not sure what kind it is. I get it from work. We have some chassis' made by a contract manufacturer that ships to use using this foam as filler. It is harder than styrofoam, denser than carpet foam and you can cut it with a kitchen knife. If Grumpy sees this, maybe he give some insight, as I know he has been looking for a supplier of this stuff.
  4. mhardy6647
    53,390
    Thanks for sharing... I have an Altec 604B that needs to go to Great Plains, and I am terrified to ship it. I was thinking about building a crate, but your approach looks pretty darned sensible.
    wolly likes this.
  5. Paulfxl
    Paulfxl Active Member
    243
    NE USA
    I've seen that type of foam in electronics packaging too,
    I'm voting that is is Polyethylene foam.
    vs
    Styrofoam which is Polystyrene foam
    vs
    Polyurethane Foam, which is the foam in place stuff. I have some grey, small celled dense springy foam that I think is also polyurethane.
    I've never found foam sheets other than the styrofoam type the are reasonably prices. I'd like to find something with a little more "spring" than styrofoam.
    wolly likes this.
  6. Dynacophil
    Dynacophil I ain't Phil, I'm 'phile
    4,477
    Berlin, Germany
    10 points of possible 10
    wolly likes this.
  7. glen65
    glen65 Member
    4,386
    Richland county, Ohio
    When that much bread is on the line there's no such
    thing as overkill. If you didnt pack it the way you did chances
    are the only thing that would get killed is the merchandise.
  8. Stephen J
    Stephen J Suum Cuique
    10,696
    North of Motown !
    I wonder if he has tried The Foam Factory on M59 ? :scratch2:
  9. Frank Zappa
    Frank Zappa Active Member
    120
    Ontario, Canada
    That packing job is almost artistic!
    wolly likes this.
  10. botrytis
    29,537
    PODUNC USA......
    Luther does everything artistic.
  11. Jedi
    Jedi Super Member
    1,882
    Tucson , Az.
    Ah yes , green polyethylene lam...1.9 dens . We have sheets of this at work . It's the least expensive of the p/e's .
  12. Jedi
    Jedi Super Member
    1,882
    Tucson , Az.
    ..Oh forgot to mention that you can use a heat gun or even a hair drier to bond these pieces together if needed . It's a much better bond than any glue will give you . I work with this stuff all day .
    Great job on the packing .
    Rudy .
    wolly likes this.
  13. theoman
    theoman Confused Member Subscriber
    2,051
    Cypress Texas
    getting ready to ship 220 lbs. used 4 layers of 3/4 pink stuff from home depot
  14. petehall347
    28,387
    uk.. the middle bit
    how many kg is that ? ..i am sorting out one now 21kg bbc monitor ls3/1 ..am having box made just need the filling now .
  15. moebuster
    moebuster AK Subscriber Subscriber
    3,068
    A small city in N.Alabama
    good luck with the shipping goons!
    buyer just sent this-
    USPS in this case but UPS can do t as well.
    A$$Holes!
    wolly likes this.
  16. jdurbin1
    jdurbin1 Tandberg enthusiast Subscriber
    8,995
    San Diego
    Perhaps instead of just ranting (you're frustrated, we get it), you might mention the specifics of how that speaker was packed?
    You can't ship large heavy items and expect them to be treated delicately, by ANY carrier. Knowing that a certain amount of rough handling is likely going to happen and addressing that with well-crafted inner pack & stout enough boxing is the key to packing successfully.
    John
    wolly and Dynacophil like this.
  17. soundoc03
    soundoc03 Super Member
    1,391
    Spokane, WA
    Fedex has boxes that they call "golf" which are double walled and perfectly sized for shipping large heavy bookself speakers. I recently used them to ship AR3a and KLH-Fives which arrived without a scratch or ding. The AR3as were actually shipped and packed by Fedex and to my horror and astonishment were just placed in the boxes without any other packing material and they still made from Boston to Spokane in one piece! (not recommended)
    wolly likes this.
  18. aldread
    aldread Well-Known Member
    615
    Atlanta
    Pool noodles... You need foam that absorbs shock without deforming or breaking. Fasten it to the edges and corners of a speaker, you'll never have a problem.
    wolly likes this.
  19. Dynacophil
    4,477
    Berlin, Germany
    A speaker should have corner- and edge-covers when packed for shipping.
    I'd pack a speaker for shipping like this:
    and it still goes better, double box...
    wolly likes this.
  20. AudioCarMan
    AudioCarMan New Member
    16
    If the seller is an occasional seller that just wants to sell his "toys" because he doesn't use them anymore, he won't probably have corner and edge covers or a long roll of bubblewrap at his house to triple-layer the speaker. I agree with you that it can be done very well, but it is also pricey. I am not saying that the items should be sent just in a box without any protection, though.
    You are defenitely a seller everybody would love to buy from and very detailed. :^ )
    In any case, some of you may think I am too extremist, but just to be sure that the items arrives in good condition, I always try to ship amplifiyer nobs in these type of boxes:
    I bubblewrap them well before, just to add some extra precaution here and there.
    wolly likes this.
