Help desk for the High Quality MC Phono Stage and Simple PSU
PCB's only available in Barter Town Parts for AK Subscribers Only
HQMCPS BOM
Qty X Mouser Part Number / Description
4 X 575-21043380 / IC & Component Sockets 8P SOLDER
2 X 505-M102.2/250/5 / Film Capacitors 250V 2.2uF 5% PCM27.5
8 X 71-RN60D-F-10 / Metal Film Resistors - Through Hole 1/4watt 10ohms
4 X 71-RN60D-F-200K / Metal Film Resistors - Through Hole 1/4watt 200Kohms 1% 100ppm
4 X 71-RN60D47R0F / Metal Film Resistors - Through Hole 1/4watt 47ohms 1% 100ppm
4 X 71-RN60D3900F / Metal Film Resistors - Through Hole 1/4watt 390ohms 1% 100ppm
2 X 71-RN60D-F-16K / Metal Film Resistors - Through Hole 1/4watt 16Kohms 1% 100ppm
2 X 505-FKP20.015/63/2.5 / Pulse Film Capacitors 63V .015uF 2.5%
2 X 505-FKP24700/63/2.5 / Pulse Film Capacitors 63V 4700pF 2.5%
2 X 505-MKP20.033/100/5 / Film Capacitors 100volts 0.033uf 5% LS 5mm (Optional)
8 X 667-EEU-FC1V101 / Aluminum Electrolytic Capacitors - Leaded 100uF 35V
12 X 594-K104K15X7RF5TL2 / Multilayer Ceramic Capacitors Leaded 0.1uF 50volts 10% X7R 2.5mm LS
2 X 652-3296Y-1-102LF / TRIMMER 1K OHM 0.5W TH
2 X 652-3296Y-1-202LF / TRIMMER 2K OHM 0.5W TH
2 X 80-PFR5221J100J11L4 / Film Capacitors 100volts 220pF 5% LS 5mm
2 X 926-LME49990MA/NOPB / OPAMP AUDIO LOW NOISE 8SOIC
2 X 584-AD797ANZ / OPAMP ULTRA LOW NOISE OP AMP IC
Off Board Components
1 X 696-SSL-LX5093IT / Standard RED LED - Through Hole HIR
1 X 71-RN60D-F-8.2K / LED Current Limiting Metal Film Resistor 8.2kohms
2 X 568-NYS367-9 / Phono (RCA) Connectors RCA PANEL JACK GOLD/WHITE REAN
2 X 568-NYS367-2 / Phono (RCA) Connectors RCA PANEL JACK GOLD/RED REAN
1 X 530-111-2223-001 / Ground Binding Post Nickel
1 X 691-2M1-DP1-T1B1M1QE / Mini Toggle Switch
4 X 534-8846 / 4mm X 8mm Standoffs for PCB
Simple Power Supply BOM
Qty X Mouser P/N > Description
4 X 652-RLB9012-103KL > Fixed Inductors 10000uH 10% .17A
1 X 163-R123B-E > DC Power Connectors PANEL MOUNT 2.1MM
1 X 553-WAU12-1000 > Plug-In AC Adapters 120 to 12VAC 1.0A 17W
4 X 647-UPW1E222MHD > 2200UF 25V ELECT Nichicon 16mm
2 X 667-EEU-FM1E221 > 220UF 25V ELECT FM
6 X 594-K104K15X7RF5TL2 > Capacitors Leaded 0.1uF 50volts 10% X7R 2.5mm LS
2 X 71-CPF15R0000FEE14 > Metal Film Resistors - 1watts 5ohms
2 X 71-CCF60-100-E3 > Metal Film Resistors - 1watts 100ohms
1 X 71-RN60D-F-8.2K > Metal Film Resistor - 1/4watt 8.2k
1 X 512-LM317T > Linear Regulator
1 X 512-LM337T > Linear Regulator
4 X 512-1N4007 > Diodes
2 X 652-3296Y-1-202LF > Trimmer 2k 25 turn
1 X 696-SSL-LX5093IT > Standard RED LED - Through Hole HIR
1 X 691-2M1-SP1-T1B1M1QE > Mini Toggle Switch
4 X 534-8846 > 4mm X 8mm Standoffs for PCB
Mini XLR's if needed:
? X 568-RT3FC-B > 3P TINY XLR FEMALE BLK SHELL
? X 568-RT3MP-B > 3P TINY XLR MALE PNL BLK SHELL,
HQMCPS BOM
