Cabdiver
Member
I have a CAL DX1 CD player that generates a humming sound which comes through the speakers. The hum gets louder as I turn up the volume. This hum occurs even with the CD player unplugged, hooked up to the amplifier with RCA interconnects. If I unplug the left channel, the hum is only heard in the right speaker, and vice versa. I've tried different cables and different amps with the same result. Running a ground wire from the ground post on the amp to the CD player chassis made no difference. I took out the main circuit board and touched up a couple of suspicious solder joints, but that also made no difference. I'm a new hobbyist with a soldering iron and a good supply of ignorance. Any help would be greatly appreciated.
