I Think I Need a Conical Stylus for a Shure V15 or Stanton 681
Discussion in 'Turntables' started by Danimal1969, May 25, 2018.
  1. Danimal1969
    Danimal1969 The Tall Guy Subscriber
    1,039
    Ok, I’m showing my ignorance here. Be warned.
    Somehow the world of styrene 45’s passed me by. I was totally unaware of this deviation from “regular” vinyl pressings. The a couple days ago I picked up some 45’s and actually found one pretty nice gem. I was informed that it was styrene and I shouldn’t play it on my “normal” turntable. I dismissed the advice because I am quite happy with my main table and a Van Den Hul cart. But I gave google a chance too and found so much info that I now confused.
    If I understand correctly, a conical stylus is what styrene records like and most others will ruin the pressing in short order. I happen to have an old Shure V15 type IV and a Stanton 681. Can somebody tell me what conical stylus I should be looking at for either of these? I guess as a bonus it will be a good stylus for albums of lesser condition as well.
    I welcome any opinions here...
  2. Danimal1969
    1,039
    Side question: what is the difference between conical and spherical?
  3. tnsilver
    tnsilver AK Subscriber Subscriber
    3,038
    Boston
    It's the same thing
    thomo57 likes this.
  4. Danimal1969
    1,039
    Is it? Lol. Well see, I really am a moron.
  5. 45rpmspinner
    45rpmspinner AK Subscriber Subscriber
    Funny thing about styrene, a nice clean NOS copy can actually sound better than vinyl. However, it does tend to show signs of wear faster.
    I use conicals with my 45's mainly because it lessens the snap crackle pop factor.
    Kinda depends on how often you plan on playing a styrene 45.
    Gotta remember that 45's were basically made for the kid market and most received considerable abuse....and often still sound just fine.
    Truth is I don't worry very much about wear from playing.....and believe me I've got a lot more invested in my 45 collection than most have invested in their system.
    As far as your original question, I do really like the Stanton 681/680, but imo the short cantilevers cause considerable problems with warped records....so I don't use them with 45's.
    And I have no experience using a V15 mk4 with 45's.
    Pretty much standard in the 45 world is the Shure M44G or 7....although I'm currently using a Shure M75 with a conical.
    Might be switching to a Grado though. Maybe run a 1 mil "mono" stylus or the cheaper of the DJ styli they make in one of the random Grado carts I have around.
  6. 45rpmspinner
    opps....misread a post.
  7. beat_truck
    beat_truck Super Member
    2,490
    SW PA
    He can correct me if I'm wrong, but I think @needlestein recommended an inexpensive TEI branded conical that sells on ebay for the 68x.
    I think ellipticals are generally OK for styrene 45s, but I do remember several people saying that certain exotic styli can damage them in one play. I think Kent T. was one of them, and I tend to believe what he has to say.
  8. Danimal1969
    1,039
    I have a D6807A stylus for my Stanton which apparently is a “spherical”. I guess I didn’t realize it meant the same as conical. Anybody use that for styrene?
  9. beat_truck
    2,490
    SW PA
    As long as it's in good shape, that should be perfectly fine.
  10. 45rpmspinner
    That should work just fine.
    As I said above, the only reason I don't use the Stanton 680/81 on 45's is because in my experience they're not great with warps.
  11. Danimal1969
    1,039
    I appreciate the feedback. I don’t have a ton of 45’s but I figured I could set up my spare table to play them and/or albums in lesser condition.
  12. orthophonic
    orthophonic Super Member
    1,344
    Winter Park, florida
    I have played mint styrene 45's for over fifty years with elipticals, Shibata, fine lines, Van Den Hul etc and have never damaged or worn one. I suppose the possibility is there if the cartridge is not aligned properly
    or the tracking force is too high.
    empirelvr likes this.
  13. Empireman
    Empireman Active Member
    226
    Are the Stanton 681 and 680 stylus interchangeable?
  14. 45rpmspinner
    Yep.
    Styli for the Pickering XV-15 [not the V-15], will work as well.
    It's the same body.
  15. steven94
    steven94 AK Subscriber Subscriber
    625
    Long Island N.Y.
    Yes Stanton 680/681 and Pickering XV-15 are all interchangable. If you go to KAB there is a cross reference for all Stanton stylus that fit 680/681 bodies.Unfortunatly they don't have one for Pickering or between the two
  16. malden
    malden Addicted Member
    5,268
    It depends on which way you slice it. Vertically it's conical. Horizontally it's spherical.
    ETI_5000 likes this.
  17. electrode101
    electrode101 Member
    81
    The only issue I ever had in my experience (as long as yours, and also in a professional capacity, dubbing music to tape carts for radio stations in the last century) was in playing a 60s era Columbia pressed styrene 45 with a properly set up Shure V15V-MR. "Little bits" of the material curled around the stylus while playing. Of course it ruined the record. However, as I said, it's been my only experience like that.
    I've never had any issues with Shibata, Stereohedron, hyper-ellipticals, or fine lines. Still, if it was an irreplaceable record, I would stick with a conical, or broad (0.4 X 0.7 mil) elliptical. YMMV, batteries not included.
    jDiamantis
  18. woodj
    woodj Super Member
    3,454
    Not really.
  19. KentTeffeteller
    KentTeffeteller Gimpus Stereophilus! Subscriber
    26,474
    Athens, TN
    The Stanton 681 would be your easiest of the two to get a conical for, the Jico D6807A would be a recommended option tracked around 2 grams.
  20. gadget73
    38,130
    Southern NJ
    Bobsblkwax and AJD1964 like this.
