I would appreciate some speaker ideas
Discussion in 'Home Theater & Video' started by EJC1, May 20, 2018.
Tags:
  1. EJC1
    EJC1 Active Member
    163
    We are in the process of purchasing a new home and of course I'll be reinstalling my home theatre in the new house.
    The area for the setup is an open area. I have access to run wire through the attic or the basement. There is no room for speaker stands or mounting on the wall
    The receiver is a Yamaha RX-A1070 so power and speaker options are not a problem.
    Front main R&L will be Klipsch Forte IIs
    Center will be a BA VRC
    My thoughts are to go with speakers mounted in the ceiling. - 2 front and 4 rear.
    I have not looked at ceiling speakers in a good many years.
    I'd love to hear ideas for decent speakers for in-ceiling mounting
    Also, will I need a baffle to protect the exposed cones in the attic
    Thanks
  2. Putterman
    Putterman Super Member
    1,350
    I have to say that you have quite the 'odd couple' of front 3 speakers of 2 Klipsch 'horn' based speakers and a Boston Acoustics aluminum "AMD" hard dome tweeter with the 'Reference-quality Boston Soundâ„¢'.
    I'd recommend either getting 2 Boston speakers with the same tweeter or, likely the cheaper alternative, a Klipsch center speaker to match the Forte's.
    As for ceiling speakers the Boston Acoustics Bravo are small surface mount speakers that would match your center. I'm sure Klipsch makes similar products that would match your fronts. You might look into automotive speakers to get a 'weatherproof' in ceiling speaker.
  3. imral3
    imral3 Super Member
    3,172
    Blackwood, New Jersey
    Are you sure you can't incorporate speaker stands or wall mounting? Once you install ceiling speakers there's not much in the way of adjusting/moving for sound quality, imaging, etc.
  4. markshan
    markshan Sir Thrift a Lot Subscriber
    13,736
    Pittsburgh, PA
  5. EJC1
    EJC1 Active Member
    163
    I've started modifying my ideas.
    I switching the front R&Ls to Klipsch RB61IIs. The Klipsch Forte IIs will be moved to my HK 500A tube amp for vinyl.
    I will use a Def Tech sound bar for the center channel
    The rear seemed to make more sense with a surface mount instead of in-wall
    So as typical, the process will evolve
    imral3 likes this.
  6. EJC1
    EJC1 Active Member
    163
    I agree these plates are a great help in making a clean install. Just got to find the right one for the project.
    I also like in-the-wall outlets with pass-throughs behind the TV
  7. twiiii
    twiiii Addicted Member
    6,580
    west Texas
    Really the 3 front channels should be identical. It really subtracts from the total presentation when the sound changes as a voice or effect moves across the screen. I know this will cause you distress. I'm fortunate my speakers though the center is half the size uses the same tweeters, only one identical mid instead of two and two identical woofers instead of 4. But the sound is the same. You might try a Hersey of the same age, to get identical tweeter and mid sound. I assume you use a Sub, so in the HT mode the sound below 80 hz for the center channel can be sent to the sub. In the stereo mode you won't be using the Hersey any way. Another reason to stay with Klipsch is the efficiency of the speakers will remain high, the idea of using a Boston with the screaming peaky highs that is much less efficient than your Forte's is going to penalize your system.
    StimpyWan likes this.
  8. PabloX
    PabloX AK Subscriber Subscriber
    313
    Massachusetts
    So is this question about the rear/side channels? Are you doing a 5.1, 7.1 or something else?
  9. EJC1
    EJC1 Active Member
    163
    The question was originally for the rear/sides/front effects. The plan was to go at least 5.1 and if possible 7.1.
    My thinking has shifted a bit and now thinking of using conventional speakers mounted on the wall.
    I also switched from the Klipsch Forte IIs as R&L speakers to a DefTech sound bar for R&L&C
    The Forte's will now be matched with an HK 500A amp and Thorens Turntable in another room.
