cube-tube
Super Member
Just received a second JL Audio e110 subwoofer, from the same gentleman that I purchased the other e110 and both Carver amps from as well as the Carver C-1 preamp I was using for a while. Both of these subs are practically new. He owned them both for a year or so and barely used them.
After reconfiguring the dbx Driverack Venu 360 for true dual mono sub output, carefully adjusting gains and phase, these little subs are rumbling out some seriously deep and strong bass. Sound stage has opened up even more, being even wider and deeper!
Running pink noise through the system shows a pretty flat response across the board, and that's with zero EQ/DSP. Only crossover points, phase and gain adjustments.
I'm sure there will be more tweaking to come.
