HaconGLosli
New Member
Hey guys! Im restoring a pair of IMF Super Compact 2. Ok lets start with the problems first.
Problem:
so the speakers dosent play all the details of a song, the speakers seems to have problems with the 4 inch driver and the domed tweeter. I think its mostly because that the foam around the 4inch is damaged and have been played with the foam damaged. The domed tweeter seems to be pretty weared out (probably because it 30years old). im pretty sure that they need to be replaced rather then refoamed. I think that the 8inch bass element is still good but its a bit hard to hear if its bad when the others are bad.
What i need help with:
Im wondering if i should replace the 4inch and tweeter with either something modern and similar or get some really close used ones, or should i refoam them? I probably should replace the capacitors too.
I dont have much expirience with Speakers but im familiar with some electronics and fixing stuff.
Tips, Info and help is much apriciated! thanks - Hacon.
Problem:
