impromptu room treatments
Discussion in 'Listening Spaces' started by K_50, Mar 9, 2017.
  1. K_50
    K_50 Active Member
    134
    Copenhagen, Denmark
    At the present I'm living in a basement with tile floors, and I'm using my bedspread to tame some of those frequencies that would otherwise be flying all over the place.
    It works quite well, so I'm curious as to what ghetto-methods some of you others might be using...
    Snoober likes this.
  2. JoeESP9
    14,919
    Philadelphia PA
    Before I moved to covered Owens Corning panels I had a couple of rugs I hung on the walls.
    Snoober likes this.
  3. sKiZo
    sKiZo Hates received: 8641 Subscriber
    You can always tack carpets to the ceiling ...
    Those are memory foam and do a right nice job of deadening hard reflections. Also fun to point to when people stop over ... "don't forget to wipe your feet!" ...
    Also, if you don't have any damp or mildew issues to deal with, I highly recommend fiberglass drapes like I used on the back wall here. Those are "room darkening" so they're thick material with a foam backing and make real decent traps. I had a killer standing wave at around 160hz that's now well controlled with those.
    Snoober likes this.
  4. Snoober
    Snoober Dysthymic
    547
    :lurk: cool thread
