In hunt for a large tape cassette deck
Discussion in 'Tape' started by sssboa, Nov 8, 2018.
  1. sssboa
    sssboa Well-Known Member
    848
    Hi guys,
    I am looking for a large deck so I could put my precious receiver on top of it. If it was quality to boot it would be a bonus. Or are they all same dimensions?
    My receiver is around 48 cm wide, 30 cm deep.
  2. Hajidub
    Hajidub Chihuahua/Pug = Chug Subscriber
    5,668
    Colorado Springs, CO
    vintagecassette.com just so I don't have to list 5,000 options.
  3. hdrobien
    hdrobien Well-Known Member
    541
    France
    There are not many large deck (> 440 mm).
    I only know the Nakamichi 580/581/582 (500 mm).
  4. mhardy6647
    53,392
    How big is the Yamaha CT-1000?
    There's one sitting atop a CR-1020 (and under a CA-800) in the photo below.
  5. sssboa
    848
    OK, I will have to put the deck on top of the receiver.
  6. Bob
    Bob AK Subscriber Subscriber
    2,666
    West coast
    look at the 660/670/680 Nak series which come in rack mount (EIA),
    you could do a simple rack with a spacer panel that supports the
    receiver. that spacer panel is if the receiver's feet is too wide
    otherwise not needed nor is the simple rack. check hifiengine
    for the NAK dimensions and lift your receiver to measure the distance
    between the feet.- do note the depth also.
  7. Hajidub
    5,668
    Bad idea, it’s best to not cover the ventilation grills.
  8. toxcrusadr
    toxcrusadr Omelette au Fromage Subscriber
    34,517
    Central Missouri
    You could use some spacers to give the receiver some air.
    HVAC vibration pads, very cheap and stackable too.
    Of course if you're running your receiver hard even that may not be enough to properly ventilate.
  9. Bob
    2,666
    West coast
    put a fan on the rear, power it with receiver's switched AC outlet.
  10. MRL_Audio
    MRL_Audio AK Subscriber Subscriber
    6,419
    St. Chuck, MO
    New one. A deck as a base for the receiver. Naks make a good base.
  11. sssboa
    848
    Thx. I will look for them to extend the clearance.
    It's a vintage Yamaha CR-800. It doesn't heat up as much as modern av receivers I had. I think it will be alright. I bought myself Yamaha kx-670 deck. I guess it has a steel bottom plate so actually may be a bit like a radiator. May it? :)
  12. sssboa
    848
    Only 4 of these cost 50% of the deck's worth :(
    I think 4 blocks of wood would :) do the job
  13. sssboa
    848
    BTW, is it your private Yamaha stack?
  14. Djcoolray
    Djcoolray Addicted Member
    6,673
    A rocks throw from JBLM !!!!
    I’d just find some kind of hardwood shelving or maybe heavy plated glass that resists vibration....
  15. Wolfman181
    Wolfman181 Active Member
    204
    It's TRUE that you need to be concerned about heating up your receiver. But to answer your question you may look for a JVC KD-95/KD-3030. Same deck but the 3030 is a rack mount. This deck is big enough I think to even fit my Marantz 1090 on top of dude. It's a really big deck. Now it is a two head but mine sounds pretty good with my Marantz/JBL system. I have not had the time yet to record anything yet but I am told the JVC superANRS system makes some nice recordings. Here a picture for perspective. I hope this helps. 20181119_130150.jpg
