Infinitesimals....How does one knows which Model it is?
Discussion in 'Infinity Loudspeakers' started by GlobalWarming, Jul 18, 2008.
  1. GlobalWarming
    GlobalWarming Super Member
    1,422
    Deutschland
    Hello....
    How can I tell Infinitesimal model .1, .2, and .3 apart?
    I have seen some in all black; did the .1 come in all black also?
    I have never seen one in person but of all the fotos that I have seen they all look the same.
    Thanks!
    Nel
  2. Coastsider
    Coastsider Curmudgeon
    I have a pair of 0.1's, one of which is pictured in my avatar, with the 5" Watkins woofer and Emit tweeter, and to my knowledge they were only sold with wood end caps and trim and an optional wall mounting bracket. From the schematics on the Infinity Classics website, it would appear that the only difference between the 0.1 and 0.2 was the crossover but I have no other information to verify that. The 0.3 apparently had a conventional 5" woofer and the Emit and was made in two models, one similar in appearance to the earlier versions except with black plastic end caps and trim, and one for use in cars which also came in some sort of black plastic housing. The crossover was obviously different than the other two since the woofer did not have dual voice coils.
    If anyone can provide contradictory or otherwise different information I will stand corrected, but the above is what I've been able to glean from available sources.
  3. phaedrus
    phaedrus Well-Known Member
    882
    Dallas, Texas
    - The 0.1 had a Watkins woofer and no "contour" switch
    - The 0.2 had a Watkins woofer and a "contour" switch
    - The 0.3 did not have a Watkins woofer and had a "contour" switch
    The 0.1 and 0.2 had a recessed area where the speaker terminals and the (exposed) fuse was, while the 0.3 had the speaker terminals flush mounted with the back of the cabinet and had a cover over the fuse.
    I'll echo Coastsider - "the above is what I've been able to glean from available sources."
    David
  4. Coastsider
    I somehow never noticed that difference before on the xover schematics. I guess my 0.1's are actually 0.2's since they have the contour switch. I stand corrected.
    You learn something new every day.
  5. phaedrus
    882
    Dallas, Texas
    Same thing happened to me, I thought I had a pair of 0.1's but they're actually 0.2s. Still looking for a pair of 0.1s.
    David
  6. Coastsider
    Since they are "essentially" the same, Watkins woofer and all, why 0.1's as well as your 0.2's, although having perused the Infinity section of your website, I suspect that I am asking a really naive question so never mind. A very impressive collection indeed.
    I guess I'll just stick with my 0.2's.
  7. cdfac
    cdfac AK Subscriber Subscriber
    6,043
    Iowa City
    are the 0.1s supposed to be better, or is it merely a collector's thing? in either case, feel free to send the 0.2s my way when you find the 0.1s!! :thmbsp:
    chris
  8. GlobalWarming
    1,422
    Deutschland
    Thanks a lot!
    This is really helpful information.....
    I would definitely like to know what I am getting......
    I have been looking at them and I would like to get a pair in the near future....
  9. GlobalWarming
    1,422
    Deutschland
    Could you gentlemen be kind enough to post fotos of at least the model .1 rear?
    Thanks!
  10. phaedrus
    882
    Dallas, Texas
    Purely a collector's thing, I have never heard that there is any substantive performance difference between the 0.1 and the 0.2. I really like my 0.2s, doubt the 0.1 would offer me anything sound-wise. I just like to be thorough.
    David
  11. phaedrus
    882
    Dallas, Texas
    Pretty sure this an 0.1.
    David
  12. Coastsider
    Looks like it has a contour switch though.
    And why would someone paint it black?
  13. phaedrus
    882
    Dallas, Texas
    You may be right, I was thinking it was slots for a cover, but it may be a contour switch. In which case, I'm not sure I've seen an 0.1.
    I think Vito has some, hopefully he'll pop in and shed some light on this.
    David
  14. Proconsul
    Proconsul Active Member
    104
    Hey guys, I'd be interested to know -- how do they sound? I presume they do NOT resemble LS3/5A speakers. To those who may have heard both Watkins and non-Watkins, is there an audible difference?
  15. yo00
    yo00 Active Member
    111
    Queretaro, Mexico.
    the rs 0.1 have grey dual coil watkins woofers and contour switch, i have one pair.
    rs 0.2 and rs 0.3 both have 2 switches and clear (0.2 dual coil and 0.3 single coil) woofers.
    best regards.
    Pio
  16. phaedrus
    882
    Dallas, Texas
    Interesting, the schematics on the 0.1s don't show a contour switch. Can you give us a picture? And what are the 2 switches for on the 0.2 and 0.3 - the schematics show only one switch on either of them.
    David
  17. Coastsider
    Interesting.
    Given that info, I don't think I've ever seen any 0.1's for sale as all I've seen had clear poly Watkins woofers. There may be lots of other Infinitesimal owners out there who think they have 0.1's but have 0.2's instead as much of this is new information to me. I'm not mad or even remotely concerned - they still look and sound just as good. It just takes a tiny bit of the edge off of their provenance, as they say on Antiques Roadshow.
  18. yo00
    yo00 Active Member
    111
    Queretaro, Mexico.
  19. Coastsider
    I think the contour switch (for the woofer) is shown just below the 1200uF cap on the 0.1 schematic.
    It is in the same place on the 0.2 schematic, with the addition of the slide switch for the tweeter.
    Yeh, what he said. I can't type any faster.
  20. yo00
    yo00 Active Member
    111
    Queretaro, Mexico.
    the countour switch is for the woofer (in rs 0.1 is marked "contour") same function in 0.2 and 0.3. the tweeter switch in 0.2 and 0.3 iirc is marked (labeled) "pressence" i think is for atenuate the hf output.
    Pio
