pauljh
My first speaker was a pair of Rectilinear IIIs (which I sold, and which are the only pair of speakers I have sold). My second speaker was the first Infinity product I could afford: the Infinity 2000. The first product, the Servo Statik 1 was a bit out of my price range as a college student. The Infinity 2000 was the precursor to the 2000A, having just two electrostatic tweeters per side, instead of four. But both used electrostatic tweeters from about 1,800Hz on up, just like their big brother, the Servo Statik 1.
I still have the 2000s, but they haven't been played for about a decade, and something is wrong with one of the high voltage supplies. I had been intending to fix them, as an homage to my audiophile history, but I never seemed to get around to it. But then fate and eBay intervened. I saw a pair of 2000As listed, and although the cabinets looked good, and all the drivers were there, they were described as having non-operational tweeters, sold as-is and local pick-up only. They were repeatedly re-listed for a lower and lower price, and finally I made an even lower offer which was accepted. Picking them up involved a 500 mile round trip, but I visited Jocko's Steakhouse, and Hearst Castle during the trip, both things I had been meaning to do for quite a while. I figured that between the 2000s and the 2000As, I should be able to get a good working pair of some very early Infinity speakers.
I got them home, and just as described, no sound from the tweeters.
So I took them apart.
Here's what the first crossover board looked like (after I removed the blown fuse):
Hmmm, the vinyl tubing around the diodes is discolored, and the capacitors in the crossover are very modern looking polarized electrolytics. Somebody has been in here before. I also measured a few of the carbon composition high voltage bias resistors and they read 28Meg to 30Meg instead of the specified 22Meg. I decided to replace everything that was outdated, or out of spec. I planned on replacing the diodes and the capacitor in the HV supply, all (8) of the 22M carbon composition resistors with metal film ones, and replacing the electrolytic crossover caps with modern metalized film capacitors. Infinity-Classics.de had a scan of a drawing of the 2000A circuitry (attached below along with my schematic drawn from the Infinity assembly drawing), so I scoped out what I needed and ordered parts from DigiKey and Parts Express.
After I replace the fuses and the HV supply components, there was sound from one set of tweeters, but not the other. In the second speaker, someone had once replaced the diodes and then connected the tweeter wires to the wrong terminals. After re-wiring things correctly, the second speaker's tweeters also started working. But we weren't out of the woods yet. There is an inductor in the tweeter crossover, and in the second speaker, it was not connected, as the wire had broken. I took it out of the cabinet to check it out, and found this:
I think I need a new inductor. Maybe two. The Infinity drawing showed the inductor in series with a 2.5 ohm 10 watt resistor going to ground. My speakers had the inductor but no resistors. I measured the DCR of the roasted inductor, and got 2.5 ohms. Aha! Someone at Infinity had the bright idea to wind the inductor with really thin higher resistance wire so they didn't have to bother with the resistor. We'll save 50 cents in every speaker! What could go wrong? If you have a big amplifier and you play these speakers really loud, that inductor gets hot enough to melt its winding form. That had happened in both of my speakers. The same inductor in the 2000s crossover was the required 0.19mH value, but it had a DCR of 0.2 ohms. So I replaced the tweeter inductors in the 2000As with those from my 2000s and added some 5 ohm resistors in parallel to get the 2.5 ohm shunt to ground.
When I was done replacing things, everything circled on this schematic was new:
Here is what the rewired crossover board looks like:
Although the tweeter circuitry was now fully operational, two tweeters in each speaker were dead. Fortunately, I had bought a box of Infinity 2000A parts from eBay about 15 years ago. The box contained four working blue RTR electrostatic tweeters. I swapped out the dead tweeters for working ones, and now had a fully restored set of Infinity 2000As. I also have the original optional stands ($5 in 1970), and after I sand, prime and repaint them, I'm going to call this restoration project complete.
