nyhifihead
Well-Known Member
Hey all I was able to pick up some Infinity Kappa 6.1 floorstanders
So far as expected for a craigslist find, woofers need refoam and one of the EMIT-R is bad. open circuit when checking continuity, this one looks sort of beat up too like like 2 minor gashes in the ribbon part.
would this even produce sound correctly if repaired? I wouldn't have a problem doing a DIY repair.
Its the 902-5754 BTW and I have 2 questions
1) is this a generic EMIT-R style that is shared with many other infinity that I see on the bay quite often or do you think I will have to abide by the serial numbers for fear of mismatched sound?
2) if the sound would be mismatched do you think buying a identical pair of EMIT-R from another infinity loudspeaker would be the best solution?
I've also found there are these plastic beauty rings glued rather heavily onto the outer of the foam surround. any tips how to get these plastic rings off the best?
very impressed by all the hardware of these Kappa 6.1s. The interior wiring for the crossover is the nicest and thickest awg I've ever seen.
Can't wait to get these fully up and running to see how they compare to my PSB image 6Ts
