-Triple protection circuit
- Heat sink is 190 square inches
-Torodial transformer for less magnetic noise coupling and highly
concentrated magnetic fields for less heat and improved power
regulation over standard transformers.
-Two huge filter capacitors of 22,000 mfd each for tremendous headroom
-170 watts per channel RMS into 8 ohms.
Vito
I admire your respect for these amplifiers but I question your experence with Infinity Kappa 8 speakers.
I'am not trying to be a wise guy here but I have personally owned Kappa 8s and 9s. They are a great speaker but they are also known as amp killers. If you don't believe me check
http://www.audioreview.com/reviewscrx.aspx. These a real reviews by real poeple who own these speakers. The Kappa 8 is a much easier load then the Kappa 9 but it is still its little brother and still presents a tough load for most older amplifers. I am not real familiar with the Sansui B 3000 but here is what I found out before I posted a caution about driveing these speakers.
http://www.randallareed.com/sansui_ba_3000_power_amplifier.htm
I know this is not a factory spec sheet but I see mention of this amps ratings at 4 ohms much less 2 ohm or less. Oh sure he says it can do 600 watts in short bursts but most any amp can.
We just had a disscution on these speakers with another member who was Bi Amping these speakers with 2 Pioneer 1250 sx.with little success. Do you really think these Sansui's are that much more powerful then the poineers? I don't think so. For 1 thing the Pioneer is factory rated stable at 4 Ohms.
FWIW Its not actully the woofer that dips into the low impedance of 2 ohms its the crossover. As the audio frequency changes it effects the crossover circuit. These circuit consist of cap and coils. These are Hi pass and Low pass filters somtimes called tank circuits. All tank circuits have whats called a resonante frequency. At this freq.there is zero resistance, this is why all speakers have a changing impedance, some are just tougher loads then others.
Sorry for being so long winded but I just wanted you all to know that this speaker needs serious amplifier consideration. I have been playing with big Kappas for 4 years now and have wasted a ton of money on amps that just will not get the job done with these speakers. I just wish someone would have told me about this so I would not have had to go to the school of hard knocks.
Also I know my spelling sux and it might make look as tho I don't know what I'm talking about. Its up to you decide. I'm just passing on my experence with thse bad boys
