Infinity RABOS
Discussion in 'Infinity Loudspeakers' started by goodolpg, Dec 2, 2018.
  1. goodolpg
    goodolpg Just an old fart trying to help.
    Anyone use the protractor type device to find their rooms settings?
    It was pretty darn easy using the online page but it appears Harmon or whoever owns Infinity has discontinued it?
  2. okeeteekid
    okeeteekid Well-Known Member
    851
    Northern NJ
    I looked on infinity's site about a month ago and couldn't find anything for the rabos kit, I needed the template and could not find it so I took a pic of the one I had and made copies of it.
    Here it is if anyone needs it, it's not the best quality but it works, if you want you could copy it or print it out.
    https://1drv.ms/u/s!AhHWCBRVD6phhCoC5XR-e7Zqakio
  3. goodolpg
    Thank you.
    I have those templates, but others might not and they are needed to do this.
    Been thinking it may be time to "dial in" my sub again as it's been a while.
    So I READ THE DANG MANUAL and it's not that hard once you have the template okeeteekid posted and ran the measurements on the cd and recorded the numbers.
    The completed chart will give you the Freq., the slider/protractor will give you the Width, and averaging the correct set of numbers (read the dang manual) will give you the Level.
    It's not rocket surgery after all.
    If you READ THE DANG MANUAL.
    Online calculator was probably easier and a little faster but the protractor thingie seems to work.
  4. okeeteekid
    851
    Northern NJ
    You can also play around with speaker placement and get good results, that's what I did with my epsilons using the rabos kit and template
  5. goodolpg
    I do tweek the positions of my RS II's sideways and forward backward occasionally and adjust toe in/out quite often.
    Toe in/out is one of the easiest and cheapest tweeks available.
    My sub has not moved a lot since I did the first RABOS setup just over two years ago, less than 1 foot actually.
    I just figured it might be time to do it again.
    "They"* say crawling around on your hands and knees and where the bass is strongest to place your subwoofer there.
    *People on the internet.
  6. okeeteekid
    851
    Northern NJ
    But the strongest position for bass may not be the most accurate position for bass
  7. Infinity!
    Infinity! AK Subscriber Subscriber
    469
    Wow, I can't believe they finally took the RABOS site down... that's really despressing. It's not like they had to do anything to maintain the website. :confused:Although I used to own an Interlude IL 120s and then an Intermezzo 1.2s, I no longer do. I sold the interlude to my dad 2 or 3 years ago and the intermezzo to my friend a little over a year ago. For the price (and especially with the RABOS kit), they were solid subs that sounded good for the price.
  8. damacman
    9,111
    Gilbert, AZ
    I was the sales rep in North TX and Oklahoma when RABOS was introduced. All of us were provided a RABOS setup kit, which I still do have. PM me if you want it.
  9. Infinitoid
    Infinitoid euphoniums, etc. Subscriber
    2,742
    Out past the Airport, Indiana
    I always used the device and forms instead of the website with my IL-60s. By choice. Now I must. I'm very disappointed that another example of Harman's lack of legacy support has appeared in the removal of the RABOS website. Did they think that all the kits had been thrown away?
  10. goodolpg
    I have to admit, using the device was pretty easy.
    Had it been difficult I would have expressed disappointment.
    How much would it cost Harmon to keep that page going?
    In the grand scheme of their company I doubt it would cost much.
    Evidently I need to take new meter readings. While experimenting using my old readings a couple months I chose RABOS off as sounding better. Sub has moved a little bit and angle of sub has changed.
