Probably not a lot. It's a combination 3-way crossover and a servo-controlled bass amp.
The bass amp depends upon a servo cable that connects to an accelerometer on the woofer. I am not sure how critical the servo feedback is to actual operation of the bass amp; I suppose you could use it as a straight amp without the servo control, it would just not have the same response as in the original system.
The crossover is sort of unusual. As I understand it, the midrange gain is fixed and the controls control the gain for the tweeters and the bass. It doesn't actually change the crossover points, which are fixed. It's really designed to allow you to tailor the balance between the three different sets of drivers.
You might be able to use it as straight crossover, but it would definitely require a lot of experimentation to make it useful.
David
